INCRA I-Box jig question/problems -long
Galen Vetterick
So after posting about suggested plans for making a box joint sled for my table saw I bit the bullet and ordered the INCRA I-Box for my thanksgiving/birthday present. It arrived late today by UPS and I thought I could get it set up and run a test. Sadly step one of the instructions cannot be completed. The INCRA web site had given this info and why I went ahead with the order: Exclusive INCRA GlideLOCK miter bar fits standard 3/4" x 3/8" miter slots with a 0.740" - 0.762" adjustment range.
Ok, so my table saw is 0.754" but the bar starts at 0.735" and there is no way I see how to get the adjustment they say. In fact it is impossible for the split plastic adjustment to expand with the tapered head screw. They were dead tight to start with and no room to expand the plastic no matter where I tried to orient the split in the plastic piece. It's hard plastic and no way can it be expanded. Nobody to call for days now so has anyone run into this? Lots of possible ideas why it does not work, recess was not large enough for plastic to expand, taper and depth of piece does not leave room to draw screw into the the plastic to expand it, plastic to hard to allow expansion, etc. Guess it sites till next week for a call unless someone has the solution. Sorry but I'm p-ssed!
Oh! and Happy Thanksgiving!
Re: INCRA I-Box jig question/problems -long
Carol
Me, too, Galen. But the fix turned out to be simple. Align the split in the washer right next to the edge of the opening in the bar, or as you are looking at the bottom of the bar, at about the 2 o'clock position.
This was after trying everything under the moon. I did call - no holiday to deal with. The technician stayed with me on the phone until I had it working. Couldn't ask for better CS.
In the end, that is where the split would up and then they would expand as needed. Good luck and Happy Thanksgiving.
Dick Coers
You should get plenty of help, there were a lot of guys putting on the hard sell on your first post. Hate it when it doesn't work out of the box. Good luck!
Alan in Little Washington (NC)
Carol nailed it. I had to do the same thing- rotate the nylon split ring before I tightened the screw because the little Bosch table-top saw I was using for I-BOX demos at the Klingspor show had miter slots that were grossly over-sized.
I never had any problem adjusting the I-BOX GlideLOCKS to my Unisaw miter slot or the aluminum miter track on my router table.
Galen Vetterick
Thanks Carol, Dick and Alan. I had tried several positions for the slot, it was at 4 when I shifted it to 2 o'clock or the opposite side of bar opening. The only way I have come close is torqueing the Allen head screw to the point it starts to twist the short shank of the Allen wrench. Not sure how long the two point contact in the track will hold over time. There is just no way I can see how the unit is advertised to fit up to 0.762" when the bar itself is 0.735" and I had trouble getting to 0.754". Being a retired mechanical and structural engineer it does make me a little more critical of equipment design!
Thanks again and Happy Thanksgiving.
PS: I got a sale ad today for the unit, price better than my purchase. :\
Don't feel like you're the only one
Henry Higginbotham
I seem to recall seeing a special right after I bought mine, too. Works that way, sometimes. I'm still well pleased, though.
Carol
Galen, as I think about it, the 4 o'clock position won't work. If the split is at 2 o'clock then the clockwise torque of tightening the screw will force the split wider, thus enlarging the disk and fitting the dado. Before I called, the math didn't work for me either. Give it a go.
And doesn't everyone find it for less AFTER they buy it? Life goes on.... Enjoy it anyway.
Re: INCRA I-Box jig
Galen Vetterick
Carol
I know that 2 o'clock is even where I started but that or any other position I just could not get any expansion. Their DVD makes it look so simple and just turn the little machine screw. Right! I had to torque it down WAY too tight in my opinion to be a workable piece. I was about to the point of chucking up the plastic and taking some off the diameter so it could open up easier. Still think it may be the answer if I ever have to adjust as it wears. I think the bar could have been wider to begin with so it needed less expansion. Even since it is offset from the center of the bar it could have been set closer to the edge with the narrow bar. I should have put a lub on the screw taper and it least the torque friction would have been less.
It is something they need to fix.
I'm beginning to slow down from pumpkin pie and Dream Whip!
This might work
Henry Higginbotham
Since the adjusting discs are both on the same side of the bar, the other side could be "expanded" by applying a strip of UHMW plastic like Incra supplies as glides for the underside of the jig. The roll I've got (Lee Valley, I think) is 0.030" or thereabouts, but the strips that came with the jig appear to be more like 0.020--just a fuzz over what you need for a snug fit without the adjusters.
UHMW cuts easily with a hand plane. I've never actually tried to sand it, but I think that once the strip is applied, the fit could be eased a bit with sandpaper if necessary, and re-expanded with the discs if you overdo it.
And if you can't immediately locate some UHMW, perhaps a couple of layers of electrical tape could get you by temporarily. Worth a try, I think.
The threads aren't bottoming out?
Dick Coers
I don't have one of these, but wondering if you may have a thin plastic washer and the bolt is bottoming out. Just thinking.
Re: The threads aren't bottoming out?
Galen Vetterick
Dick
I thought that the tapered head screw was bottoming out as even the steel tapped hole has a similar small taper to the plastic disc. I had tried to put a washer under the part so the screw had more depth but it had little effect.
I got an email that a factory person will contact me on Monday. There initial comment was it should adjust easily to my saw and maybe the bar is defective.
I just think there are a lot of things that have to be right for their system to work and something went a skew!
So I'll just go back to turning till Monday.
Mark Mueller is probably the one who contacted you. I sent him an e-mail giving him a heads-up about your problem.
These miter bars are just short versions of the ones supplied with INCRA miter gauges. They are machined in large batches, and it is possible, though unlikely, an undersized one ended up in the batch.
Like you said, it could be any of a number of simple reasons. I also wondered about the possibility that the set screw was bottoming out. Another one is that somehow the hole in the nylon split ring became enlarged. If so it won't spread as far as one with a hole the right diameter.
I'm sure INCRA will make it right.
Anyone see the latest NewWoodworker dot com email? The I-BOX was selected as the #2 in their 8th annual Top 10 Tools list for 2012.
Carol
Mark was the guy I talked to. Nice guy. Patient as all get out. He stayed on the phone with me until I got it working right. I just had to learn to really listen to him, as opposed to try and force my thoughts on what was going on. Thought I was right, too. I wasn't. Pulled up my big girl britches and now all is well. :)
Galen Vetterick
Alan
The email contact was from Chris Taylor who advised Mark Mueller will be in contact Monday. I chuckled a little at your link to review: "but has an adjustment range of 0.740" to 0.762" to fit the ever-frustrating slots of equipment made by people like Sears." They guessed it, my table saw is an old Sears and ever frustrating. It is interesting to note that in the pictures in this link the slot is in the 2 o'clock position as Carol suggested. Dang smart gal, she should write the instruction suppliment and be given credit. It could be the plastic ring countersink is bad because when I first tried to tighten it it took great force to break it free. Even the washer I put under it would not help if the taper did not allow expansion. I would think they could easily say what the bar width should fall within, since mine is 0.735" and sending out new plastic insert and screws would be an easy try. If the guide bar was machined off that woud be a little more trouble. Guess I will wait and give them the oportunity to help.
Carol
Gee thanks, Galen. I always wanted to write the instructions for tools but never had the opportunity. Maybe its not too late. :) In fact, my dream job would be writing for Lee Valley. But I doubt they need me. Maybe Incra? :D !
I think INCRA miss something.
Galen Vetterick
My email from Mark at INCRA probably best answered my problem or their design error depending on how you look at it.
He sent an instruction sheet addendum for a New and Improved GlideLOCK miter bar. This sheet shows how by using disc on one or BOTH sides of a bar you can get three ranges of fit. From the figure 2 showing only white discs on one side you can get a 0.735" to 0.745" range. In figure 1 it shows black disc on the opposite site with 0.745 to 0.755" range. The last figure 3 shows white discs on both sides to cover 0.750 to 0.770"
Since the I-box I have only has white disc on one side it will never get a tight fit in my 0.754" guide as I see it. Nor is the on line advertised range possible.
The sheet also calls for the disc slit to be 1/16" away from reaching the opening or near 2 o'clock.
Maybe they should not have used their standard undersized bar of 0.735" or at least put true range of adjustment in their add for what they made.
I've ask what they think is best so I do not have to worry about keeping pressure to one side of the jig while using since my wood runers do not need that on my homemade jigs. Mine are right on as long as I keep waxing the table good.
It would be nice to have a bar with disc on both side then it woudl fit other saw I hope to purchase, someday.
Was still nice to get a reply today and not wait till Monday and before I tried homemade fixes.
Carol still looks like a good future job to write instructions and of course get a new tool each time to insure how it goes together and works. You might need to know how to translate Chinese to English for some tools. :D
