Butler tray coffee table hinges
Dave in Bryn Mawr
Am repairing and refinishing the above. Several hinge screw holes are enlarged, hence screws don't hold. What is the best way to fill the holes? I've tried match sticks but find it hard to center the screw. Somebody suggested putting CA glue in the hole then packing it with sawdust. Does this work? What is your favorite?
Re: Butler tray coffee table hinges
Yonak
Dave, you could drill out the hole large enough for a hardwood dowel insert.
I got this neat gadget at a trade show one time which is a conical-shaped reamer the shape of a sharpened pencil. The idea is to drill out the screw hole with it, sharpen a dowel in a pencil sharpener, glue it in, trim it off and set the screw in the dowel.
I'd go with the dowel too
don't use CA.
Bill Tindall
It is not a permanent adhesive. Fashion a sick, flat grain if you can muster it, and drive it into the hole with some glue.
William Duffield
Dowels for plugs are not a good idea, because screws into end grain are temporary, at best. They last a lot longer than screws in CA, but not as long as screws in face grain.
Get a plug cutter and a matching diameter brad point bit, and make plugs from face grain and glue them in. Regular yellow glue works fine for this. Then trim them flush and pre-drill the screw holes in the plugs.
I am with William on this. I regularly repair screw holes in door jambs by drill a hole, inserting a plug of face grain wood made with a plug cutter with some yellow glue, trimming it flush with a chisel and re installing the screw. You can make the plug out of similar wood if you have some, but its not really important because the hinge leaf will hide it. A quarter inch plug should work for this.
I make about thirty at a time and carry them in my remodeling tool kit.
