Source for "rough" wood
A.J. Hamler
A.J. Hamler
I'm looking for wood that's rough-looking, maybe about the roughness you'd have on pallet lumber. I need it in 1/4" and 1/2" thicknesses plus some that's anywhere from 6" to 12" wide, though, so I can't use pallets. (Plus the nail holes and wood type would be a problem.) Also, I'd prefer it in a softwood, anything in the SPF family, but I'd go with a lightweight hardwood.
Any ideas where I might find a source for this? Or, any suggestions how I could make regular lumber look rough cut, but naturally so? I tried a wire brush and 40-grit sandpaper, but it looks like wood that's been hit with a wire brush and 40-grit sandpaper.
I've seen lots of rough-cut lumber at suppliers, but it's all way too thick -- I'd have to mill it to the correct thickness, and there goes my rough surface one one side.
Thanks.
Re: Source for "rough" wood
Dick Coers
Try dragging some backwards against a course running bandsaw blade. Skew the board to a slight angle, and let the blade work like a rasp. Go easily of course since it will want to pull the blade out of the guides.
Bruce, a MN Galoot
Some rustic, rough sawn fence boards have at least one side that sounds like what you want, but it's a bit thick, so it'd have to be planed down or resawn. I don't know how that finish was produced or how to make the second side that way. Well, maybe resaw a board with a really coarse bandsaw blade?
Nat Robison
Disclaimer: I'm no expert in rough-sawn wood or how to produce it. That being said, where I buy my rough-sawn lumber, I believe they do what's called "skip-planing" to produce the rough-cut boards. If they can do that on 1" and 2" stock, is it possible they can do it on 1/2" stock? Ask your lumber supplier how they produce their rough boards and if they can do it on the thicknesses you need.
Dick Coers
Nate,
The rough sawn is straight off the blade, either circular or band. Skip dressing is running it through a planer at a specified thickness that may or may not clean up all the rough sawn. Some boards come out completely smooth, others are a combination of planed and rough sawn.
Nat Robison
Thanks for clarifying. I just noticed some wood in my garage. Some is fairly rough and others would only need a bit of work to be usable. I think I get the concept.
Kneale Brownson
Rough texture for wood.
Kneale Brownson
Softwoods can be rendered to a rough texture by sandblasting. I've seen it done on pine and cedar, both of which are available in the widths you want. The results were spectacular. You'd have to bandsaw or plane the unexposed side to get the thickness you want.
Couple of thoughts
DizD
Find a custom band sawmill and either get boards sawn for you direct or get store bought boards and have them resawn. Band resaw is the source of most pallet material. You might find what you need at a plant that produces pallets. Thin boards of syp or poplar would dry rapidly if you don't need to set the pitch with heat. I also use 36 grit on my Performax drum sander - it will leave a surface that feels like a blacktop road.
Bill Leffingwell
I have been buying and using rough cut lumber for over 20 years and have never seen wood cut in the thicknesses you want.That said there are many sawyers that will custom cut lumber to your specs.I would check around for small mills if you can't find any you might try calling the Wood-Mizer Band saw people and they probably could locate someone to do the job.The wood would be green and you could air dry it or possibly have it kiln dried.I would think thin (1/4&1/2) stock might have problems with warping.particularly in the wider stock.
Bill Leffingwell
Here is the link
http://www.woodmizer.com/us/ResourceCenter/FindaCustomSawyer.aspx
resaw
Bill Tindall
Thin pallet lumber is resawed from 4/4 lumber with a back saw/mill. If you want to replicate the look simply resaw what ever wood you want.
AJ, Here is a link, *LINK*
Keith Newton
The list is alphebetical by state.
http://www.woodweb.com/cgi-bin/directories/sdd.cgi
A.J. Hamler
A.J. Hamler
Thanks, guys! Some good ideas here.
Re: Source for "rough" wood *LINK*
AJ contact Alf Sharp. He has a warehouse full of rough sawn lumber. It may not be rough enough for you but Alf can certainly answer your questions.
http://www.alfredsharp.com/
