Veritas - Innovation in Tools
Slightly OT-Bathroom remodel declared "Open"
Alan Young
Alan Young
Longer ago than I wish to admit-I began a remodeling of our bathroom. This write-up is as edited as I could be-still quite a few few pictures to wade through.
Here is the lovely pink bathroom- demolition just underway.
The problems began when the shower would leak through the walls and floor into the kitchen below. Several attempts to fix the leak were fruitless. So one Saturday when I had had enough I grabbed my sledge hammer and Sawzall and went to work.
After a thorough examination of the plumbing-(all galvanized and cast iron) It was decided that a gutting of the entire house's plumbing system was in order. I am not a plumber but my son-in-law-Greg and I played plumbers on this project.
After systematically mapping out the entire plumbing system from the water meter on wards-we determined what types of connectors we'd need. We were able to re plumb the entire house in one weekend. Here are all the dead galvanized and cast iron pipes.
After the new lines were all run it was time to demo the walls and the ceiling. What a mess that job was. Plaster really is heavy to remove-But with a great deal of help from son-O'Neill it was removed...
While all the walls were bare and the floor was open- we ran a new electrical line from the panel in the basement to the bathroom so the room had it's own circuit.
O'Neill helped me with the subfloor. Then I framed and installed a new window-
Over the summer my SIL and BIL came for a visit from California. They insisted on spending a their brief time with us helping on the project- SIL sanded and painted the old clawfoot tub.
BIL helped with more wiring, drywall and trim work.
I finished up wall treatments and painting the then sons Spencer and O'Neill helped tile the floor. We started with Ditra underlayment-
Then moved on to tile installation
O'Neill helped install the new toilet then I grouted the floor...
Once the floor was grouted I cut and installed the baseboard.The baseboard treatment is in three sections- a high solid section with a molding on top and 3/4 round molding at the base.
The baseboard is painted and the pedestal sink is installed.
A week ago-Greg, O'Neill and Spencer helped haul the cast iron clawfoot tub up the stairs to the bathroom.
This past week I finished hooking up the tub and installed wall sconce lights.
My camera settings make the room appear dim with the lights on but-the room is really very bright
There are a few more details to go-including install all the towel bars and shower curtain, we are also looking for an older mirror to fit between the sconce lights. and I need to re-mortise and hang the door as it will swing open opposite of the original mounting. But all the lights and plumbing are now functional.
Re: Slightly OT-Bathroom remodel declared "Open"
Jerry Nicholson
Do I see some "GatorBite" fittings in your plumbing? What is your opinion of those? I have some but I haven't used any yet.
My first bathroom remodel, triggered by some water damaged flooring and subflooring, took a year and cost me six times my original $1000 estimate (1984 dollars). I don't know what it would have cost if I hadn't done all the work myself. My second bathroom remodel was much less ambitious and cost a lot less money!
Jerry
Wow!
Tony - Memphis
What an amazing transformation! Nice work. Love the period look you acheived.
We just got a new water heater (14 years out ot the original). The plumber used the pro type solderless. Having never seent hem inperson, I was interested and asked lots of questions. Pretty neat system. He said they have not had any issues. He mentioned the Gator type and said the did use them in applications where a leak would be noticed right away, they preferred not to use them. No real data, just a gut feel kind of thing. I would try them if needed. No leaks so far. We have a few spots on the ceilign, but only because the gasket for the pan pipe leaked. What a bummer. I never thought to check that. I test the drian lines yearly, but now I wil check the connections too. Might put a dab of silicone around them. He put in a new pan and gasket, so we are probably good for now. THank goodness the water shutoff/alarm worked.
Tony
Been there, done that, didn't like it...
Merle
but yours looks great.
Alan Young
Alan Young
There are a couple of Gatorbite connectors- Lowes brand--most are Sharkbite from Home Depot. When we set out to plumb the entire house I bought a 3 way crimping tool for the pex rings. Most of the connections were with the rings although the Sharkbite/Gatorbite connectors are really quick. The removal tool for the SB/GB connectors is very handy and well worth the small price. I haven't done a complete tally but there is no way I could have afforded the labor on this job. A few beers and Pizza's was plenty to keep my helpers employed. :^)
Alan Young
Re: Wow!
Alan Young
Tony-The water heater is the only thing we did not replace as the current WH is only 5 years old. My son-O'Neill made a "map" of all the lines and were they were in the floors and walls so we could 1.make sure we didn't nail/screw into them and 2. Know where to "Dig" if we ever needed to...Most of the plumbing connections are visible/accessible -Still there are a few in the bathroom floor and wall that would now require demolition to fix should they fail. Just have to trust they will be OK.
-Alan
Alan Young
Re: Been there, done that, didn't like it...
Alan Young
You know I really enjoyed every step of this project but I'll admit that as I look back at pictures of the demolition/ and early plumbing/wiring stages I get a heavy feeling in my gut-not cause I'm concerned just because I now know how Long it takes! My wife is a Saint!
-Alan
John McGaw (Bodger)
That just reminds me why I've been putting off my two bathroom remodels for 15+ years (and counting).
Nice job Alan!!!
Jennifer Indy.USA
Excellent overhaul Alan! Looks fantastic from this end. We're in the middle of one ourselves. We'll post before and after shots when it's done. Since it's our only bathroom, we're frantically working to keep the project moving! Camp showers in the shop on the brink of winter are not relaxing!
Nice job on the remodel.
Alan Young
Alan Young
It's our one and only too! I look forward to seeing what you and Clay come up with-Floors and sink treatments will certainly be inventive I'm sure!
Do you need a...
Tom Dunlap
...bathtub inspector!? I'd gratefully do the job :D
Wonderful overhaul!
You took on a 'lead-to' project and followed to completion. YOu deserve a chuck on the shoulder!
Tom
