Spray Gun Advice
Barry
I have a new HVLP spray gun that I bought at Woodcraft. It sprays much better than the Harbor Freight model I’ve been using, but when I spray with it, the surface is a bit rough, almost orange peel-like.
Yesterday, I was spraying Sherwin-Williams sanding sealer, thinned about 30 to 40 percent. I warmed the shop up to 72 degrees starting about 7 AM and took the can of sealer into the house to warm it up. I’m spraying at 30 lbs at the regulator on the compressor, with a 50 foot, 1/4 inch hose. I know I’m losing pressure through the hose, but don’t know how much. I have hesitated to just crank up the pressure, because it is an HVLP gun. Do you think I just need to crank up the pressure a bit? Or get a shorter/larger hose? Or, get a regulator for the spray gun? Or, all of the above? Thanks.
