I have a Rockwell Super 900 RAS that my father bought new back in the 1950s. It's a great saw, but my setup for it was terrible. The saw was on it's original rolling stand and I had two separate benches cobbled together on either side of it against the wall behind my workbench. The whole thing moved around like a snake and it was impossible to keep the saw aligned and square. Finally, this Summer I had enough. I ripped out the old set up and built a new RAS bench with lots of drawers and storage space for my mortiser, tenoning jig and saw blades. I modified the RAS fence so I can remove the entire left side of it to give me access to the bench top for a work surface. Finally finished all the little details yesterday.
It occurs to me that with only minor changes that bench would make both a great kitchen island and/or boat storage. I especially like the deep "tray/drawers". Good on ya.
One of these days I'm going to rebuild our kitchen cabinets. My wife will probably divorce me, though, because I'm so slow at completing projects. I can't imagine her living with the mess for more than 10 or 15 minutes.
Do you have any closeups of the saw in between the cabinets? How are the 3 tops tied together or leveled? This looks like what I need to build for the Dewalt GWI I bought this past spring.
I just posted a long explanation with photos on the North Carolina Woodworkers site. Follow this link and scroll down to my post. It should answer your questions. If not, let me know and I'll give it another shot here.
Do you have any shots of how you have the saw & the side cabinets attaching to one another? I'm guessing you leveled the 2 cabinets & placed the saw on a shelf between them.
Good guess. The cabinets were built as individual boxes. I placed them on a 2X4 base, shimmed them level and bolted them together with quick connect bolts (see link below) - 4 bolts connect each pair of boxes. It makes a very solid cabinet base.
I incorporated a leveling mechanism for the saw. I first glued a 3/4" plywood shelf in dados cut in the sides and back of the saw cabinet. I installed four T-nuts in the the fixed shelf, one at each corner of the saw. I threaded machine levelers in the T-nuts with their pads up and put a lock nut on each leveler that can be tightened against the T-nut to keep the leveler from vibrating loose. I cut triangular access holes for each leveler so I can get to the lock nuts with a wrench with the saw in place. Then I added a second shelf that rests on the leveler pads. The saw rests on this floating shelf. It can be leveled with the bench top by adjusting the machine levelers up and down. Once it's adjusted level, I can lock it in place by tightening the lock nuts.
Here are two photos of the assembly. The first is the fixed shelf with the levelers and the access holes. In this photo, you can see the heads of the quick connect bolts joining the saw cabinet to its neighbors. The second photo shows the floating shelf in place. Of course, you can see the saw in place in my original post.
That's exactly what I was wondering about. I was thinking about building something like that, or just running the top across the cabinets & then level the saw to the top. I was thinking that if I made a shelf I could set the saw in below the cabinet top I could just level the saw once instead of leveling the top to the saw then the saw & top to the cabinets.
Thanks for the additional photos. Nice to see an idea I had already realized. Cheaper & easier than designing with wood.
Yes they do. About six months ago I replaced the first part on my 900, other than the wood table. The original toggle switch gave up. I was able to find a near exact replacement. While I had the saw apart I also replace the original cord and plug.
The wood table has been replace a couple of times. The last time I replaced the table I was not able to get 5/4 C-fir like the original table had. 5/4 poplar was available though and I used that.
