ADVERTISE HERE - FREE TRIAL
Stilh Chainsaw
Stilh Chainsaw
Stilh Chainsaw
ceccotti
I have a MS 180 Stilh chainsaw that I have been unable to start. I have checked the spark and the compression. Both are very good. I also am aware it could be fuel, however what puzzles me is when I spray starting fluid directly into the cylinder I don't even get a sputter. Is there a safety switch somewhere which prevents the firing?
Rancy
Re: Stilh Chainsaw
Jesper, Denmark
Re: Stilh Chainsaw
Jesper, Denmark
The Stihl switch has three positions:
Highest up: Off and no ignition.
Middle: run.
Lowest: Start with choke requires that you hold in the trigger while moving the switch to this position.
Once the saw starts from the lowest position, the switch moves to the run position as soon as you operate the trigger.
So: Hold the trigger in while moving the switch to the bottom position and try.
Re: Stilh Chainsaw
Re: Stilh Chainsaw
Some Stihl tools used a reed valve that, when it fails, will prevent starting. We have a weed whapper with this "feature" and problem. It's a known problem with the Stihl tools with that valve. You might contact your Stihl repair shop to see if they have ideas; I know it's hard to spend money (I suffer the same problem), but sometimes it's worth it.
Re: Stilh Chainsaw
Re: Stilh Chainsaw
Chuck in mtl.
Check the reed valve as was suggested and be careful using starting fluid....you can easily damage the motor.
Re: Stilh Chainsaw
Re: Stilh Chainsaw
C. John Hebert
Old gas...put some fresh gas in
Re: Stilh Chainsaw
Re: Stilh Chainsaw
Justin Szeliga
These guys are great. The wood central of wood harvesting.
http://www.arboristsite.com/chainsaw/
I just pull the plug & drop a little, very little, gas in when I've starting problems. Usually it's old gas as as C. John said. I dump my chain mix into my truck afer 2 weeks or when I can't remember when I've bought it then ge fresh when I need it. Old gas, like 3 weeks or a month, will make you think you need a new saw.
Re: Stilh Chainsaw
Re: Stilh Chainsaw
Kurt
I don't know if this will help or not. I had a similar problem. I could usually get my saw running after perhaps 5 minutes of pulling. That crap got old. I replaced the plug though the old one looked fine. No help. What finally worked was to increase the idle. I turned the screw about 1.5 turns. I use my saw occasionally, once or twice a year. I've taken to just making enough fuel mix for the job at hand and dump any leftover into a vehicle fuel tank. I figure the little bit of 2 stroke oil diluted in 10 gal. of gas isn't going to matter. I also empty the saw's fuel tank after use then start it and run it til it quits so theres no old fuel sitting in the carburetor.
