Splitting Hollow Wooden Column
John McGaw (Bodger)
I have been fiddling with building a library/gallery room downstairs for a couple of years now and am feeling an urge to get back at it. The next task involves wrapping an ugly metal lally column which is exactly in the middle of the 24 X 16 room. When I replaced the wooden columns on front porch I saved two of the most sound old columns figuring that they'd be fine for a non-load-bearing application. This should be a pretty simple process, strip the selected column, prime it, build a pediment of suitable size to support the fake column and hide the outlet which will reside there, build a capital to enclose the slightly enclosed beam above and allow the wiring to the outlet make a graceful and concealed descent down the metal lally, cut the wooden column to length to fit the space between capital and pediment, split the wooden column lengthwise, put column halves in place and glue/nail/fill the gaps, sand, paint.
OK, all of that is pretty straightforward except for the splitting of the wooden column. I've been going crazy trying to figure a simple, safe, neat way to do it. I've even considered shooting chalk lines and doing the deed with a dozuki to achieve a thin kerf. Does anybody have an idea they might offer of a good way to tackle it? I've got a bandsaw and a tablesaw but guiding an eight-foot long eight-inch diameter column cleanly through either of those single-handed seems to be pretty iffy.
Re: Splitting Hollow Wooden Column
One method
doug f, san clemente, ca
John - I'd be inclined to build an L-shaped carriage about 8 feet long (plywood), screw it to the side of your column and run the whole thing through your band saw with the carriage against the fence.
My $0.02, YMMV
Doug
Yonak
John, could you do it with a sabre saw or a Sawzall ? They have reasonably thin kerfs. It's not like you need a perfectly straight cut.
What's the difference between minimum and maximum diameter of the column, and how thick is the wall? I'm picturing a couple of boards hovering over the column, atop a box that contains the column rigidly, and a skilsaw running down the boards, guided by battens on each side of the shoe for a straight cut. You might have to finish the cut with a handsaw and plane the mating edges flat.
I'm with Doug and Bill
Bill Tindall
Capture the column is some "box" and saw the box apart with table saw or skill saw depending on what you have and are skilled with. If you use a 1/16" kerf blade it can reassemble with little loss of size. I have excellent success running these thin blades on table saw.
Re: I'm with Doug and Bill
Clementine
Holding the column securely and safely is the main thing. I have a picture of splitting your column that resembles a sawmill slicing a log. Maybe you could watch a couple of videos of that and get an idea. I also wonder about weight - a cedar column is one thing; oak is quite another thing. One other thing: Have someone with you when you cut it - Someone to be there during the process who will respond when you shout, "Quick. Hand me that!"
Split it on the Bandsaw, doesn't really matter if you are dead straight. You could actually cut a wavy pattern while splitting and the column would glue back perfectly. Just like cutting a puzzle piece, anything you take off one side is left on the other. I would use a thin kerf blade to remove as little material as possible.
Bill Tindall
I like the band saw idea but it needs to take into consideration the log sawing thought. This "log" must not roll while sawing. Simply fixing the column to a 1 or 2 x 6 and using the edge of the 1 x 6 to ride the fence could work. And yes, help at hand would be a good idea.
Ralph Lipeles
Can't you just split it like you would do a piece of firewood. Secure the column to some, climb up on a stepladder and a large blade like a butcher knife or a machete. That will give you good surfaces for self alignment when glueing back together.
John McGaw (Bodger)
That doesn't seem as though it would work but who knows. This column is made of fairly soft wood, probably pine, and is composed of eight segments which were glued together then turned on some sort of humongous lathe back in the mid-60s. It is clearly a product of mass production and there is no telling what is going on in its construction. For example, was the stock back then pieced together from short clear pieces with finger joints as so much paint-grade trim is now? I get the feeling that I'll have to bite the bullet and rig some sort of jig the whole length of it no matter what the final method of sawing might be.
Ralph Lipeles
John,
OK. If you want to try the sawing approach, I would not make a jig. I would use a saber saw as has been suggested. You will then end up with a less then perfect straight cut which will help to align the halves when you go to glue it back together.
Ralph
John McGaw (Bodger)
No doubt about it -- put a jigsaw into my hands and the results are going to be wavy.
Ralph Lipeles
Will you do the cutting before or after your daily Manhattan?
Ralph
No way would I split it
Maybe you're better at splitting than I am, Ralph, but when I split firewood or other wood, I wind up with a lot of splinters and wild splits that would look like [insert word referring to the place of eternal punishment] when I tried to glue it back together.
John McGaw (Bodger)
No alcohol or drugs involved. I simply can't seem to get a decent cut with a jigsaw. Maybe a stiff drink might help me to do better -- it couldn't make me any worse.
Re: No way would I split it
Ralph Lipeles
My experience is the same as yours. I periodically have to glue something that broke or something that I intentionally split. There are almost always some splinters out of place. I carefully inspect and remove the ones that look like they will interfere with a sharp xacto knife.
Ralph
Jim Hoeller
I would try to find a custom saw mill with a bandsaw mill and have it split there.
Joseph Mulherin, sr
John, here is what I would do.... screw the columns to some 1x10" pine at a 90deg angle; that way you would be able to use your table saw better control with the boards attached. When one side is cut just flip it over and do the other side using the same boards already attached. You will loose only the width of the saw blade and you can glue everything back in place and no one will now the difference..... and if you tell them you will be considered a master of woodworking....lol.
Chuck Hans
Here in Kentucky, we would just say here, hold my beer, and watch this!
Just kidding,
Justin Szeliga
In Jersey I learned how to do it while holding my own damned beer. Sumbuddy woulda took it if I handed it to them.
I'd snap lines down the column, screw it to a couple saw horses, screw a square cap on each end to hold it together & to keep it from rocking, then cut it with a circular saw. Then biscuit it every foot or so & glue it together with thickened epoxy & clamp it with the big Aeroseal clamps I bought years ago to glue a couple columns around PT framing members.
http://www.globalindustrial.com/p/plumbing/hoses-and-hose-fittings/hose-clamps/hex-screw-aero-seal-clamp-7-1-8-min-10-max-2
Sand it to round when everything sets up
