yup
Bruce, a MN Galoot
crude and rude and not much explanation. What I did was make a frame of 3/4" oak and skin the top and bottom with 1/4" oak plywood. There is a space in the back with a 3/4" strip with a 3/8" rabbet running the length of the shelf (minus the 3/4" frame on the sides). There is a corresponding rabbet on the support piece that is screwed to the wall with 3" Torx-head deck screws. It is a tight fit, intentionally. This shelf is 30" long and holds pictures, etc., on our bedroom wall. I have no idea how much it would support, but it's pretty strong and very secure.
I initially designed this to use a French cleat, but there was no angle I could find that would prevent the shelf from camming out. What I was trying to achieve was a support that was not visible, even from underneath. With the final design, you can see the support, but you need to be right under the shelf to see it.
I don't know if this is easier than just buying a floating shelf support but I like to do cheap and make it myself.
