A55 Smoothing Plane
OT - Garage Door Transmitter/Receiver
Ralph Lipeles
My garage door receiver used to have a range of about 50' from the transmitter. It has significantly diminished. I new need to be 5' to 10' from the door for it to open. My transmitter battery is good. I have even purchased another transmitter and that didn't help either. I added an additional foot of wire to the receiver - still no help. Any ideas?
Thanks for your help,
Ralph Lipeles
Re: OT - Garage Door Transmitter/Receiver
del schisler
probly is the reciver . Adding extra wire will not work, it is cut to that frequency of the unit , Depends which unit you have you may be able to call the company and get a new PC board and install your self??
John McGaw (Bodger)
It is possible to buy external transmitter/receiver pairs. I added one to an old opener that was in this house when I bought it but which had no transmitter. Maker is Chamberlain but is sold under the Craftsman name at Sears. I chose this one since the new lift in the other bay was from that maker and I wanted the other one to work with the same transmitters. Otherwise I could have bought several different types from different makers.
walta
I had the same problem last year.
1 Replace transmitter batteries
2 Reprogram the receiver.
3 Replaced the transmitters
4 Replace the receiver.
5 Turned off my main breaker and power opener from generator.
All with no success.
After spending over hundred dollars for parts and hours of time over a few weeks, suddenly the problem was gone and has not return to date.
Today a lot of equipment is using that frequency band. I think my problem was a low battery in a wireless alarm sensor in my neighbor’s house.
Walta
