Plexiglas Chalkboard
don stephan
Want to make some attractive 3' x 2' sidewalk A-frame chalkboard message boards, which our community allows. Considering M&T white oak or cypress frame with chalkboard panel screwed into rear rabbet. 3/16" Plexiglas would seem to be a good panel material for its balance of stiffness and weight. Can anyone suggest how to paint primer on Plexiglas successfully? Thanks.
Re: Plexiglas Chalkboard
Ralph Lipeles
I've never done it but I would expect that you would want to sand the entire surfac to be painted with maybe 100 grit paper.
Ralph Lipeles
Lee Schierer McKean, PA
The big box stores carry a smooth melamine surfaced tempered hard board panel that works great for dry erase markers. It would be a lot easier to make into your stands than trying to paint plexi glass.
Lee
Dick Coers
I'd suggest black formica on MDO plywood, and use liquid chalk markers. Those are the kind of materials used in the commercial outside boards.
Update
I was just watching a show ("I Want That")and they had a dry erase paint that can be used over any paint to make a wall into a dry erase board. That paint would allow you to use plain old plywood with your choice of paint colors for your panels.
Lee
don stephan
Thanks for the replies. I'm trying to avoid plywood to keep the weight down. When I called a local plastics distributor to ask about Plexi, the salesperson suggested I look into PVC foamboard - some brand names are Gatorfoam, Celtec and Sintra. From what I found on the Internet, they all take paint very well and at least the first two claim some weather resistance. A 3/16" x 4' x 8' panel was quoted at $30. I may try dry erase marker first.
