Leveling floors
Leveling floors
Leveling floors
Lynn Reedy
I am in the process of removing my kitchen and foyer floor to install
2 1/4 inch wide red oak flooring. I have nothing on these floors at this point.
My concern is two fold. First my subfloor is half inch thick, built in 1989.
No t&g as a subfloor. My plan is to put 3/4 inch thick red oak on the floor.
Has anyone encountered any floor problems working over 1/2 inch thick
subfloor? Second concern is that I have a slight floor dip at the edge of the room.
I want to level this out and a friend told me about a product that when mixed with
water and applied to the floor it will level so flooring can be installed. Anyone have
any experiences with this product good or bad?
Thanks,
Lynn Reedy
Soddy Daisy Tn.
Re: Leveling floors
Re: Leveling floors
Boy, that seems really thin. What's the spacing on your floor joists? You may need to consider adding some underlayment plywood.
I haven't directly used the floor leveling compound, but the tile guy who did our bathroom used some, and it seemed to work quite well.
Re: Leveling floors
Re: Leveling floors
Lynn Reedy
Bill,
Thanks for the reply. Floor joist are on 16 inch centers.
I feel sure it will work cause I have a small room I did several
years ago and so far it is great. Doesn't hurt to ask.
It is a small world with you living in Sebastopol. My son lived
there till lately and he moved to Occidental Ca. Hope the spelling was correct.
Thanks for the help
Re: Leveling floors
Re: Leveling floors
Bill Howatt
Is the only thing covering the joists the 1/2" ply? If so, I think that doesn't meet code. While you aren't going to fall into the basement if that's the case, the excessive movement may cause squeaks in the hardwood later on.
Whatever sub-floor you have make sure it is well screwed down to the joists before you cover it to eliminate another source of squeaks.
There is self-levelling compound but take the "self-levelling" with a grain of salt. It is best to plan on helping it a bit. The good stuff is concrete based and it can get expensive if you need a lot. If you are nailing the floor there may be a maximum thickness you can apply such that the nail will penetrate it. This isn't an issue if your floor is a floating type.
If the dip is fairly large, whatever that means, I would fill it with thin ply and then smooth the edges of the filler to the subfloor with the leveller. Other things that have been used to fill shallow dips in floors are roofing shingles, roofing felt, vinyl flooring, panelling, you get the idea.
Bill
Re: Leveling floors
Re: Leveling floors
Lots of houses locally were built with half inch subfloor and then something else on top, such as particle board or oak strip flooring. It was nearly stand practice around here for a while. I am sure you will be OK putting the oak onto the half inch plywood if the oak runs perpendicular to the joists. (In fact, you can run the oak directly on the joists and I have seen that on some f my inspections. Before there was plywood it was common to run the finished flooring on the joists, but it was usually 5/4 t&g pine here) If you want to double check you can go to that NOFMA site I mentioned earlier and read the installation documents. Buried in there somewhere will be a list of acceptable subfloors.
If the dip is parallel to the joists, you may be able to put a strip along the wall to support the ends of the flooring.
Back in the day it was considered important for the nails to penetrate the subfloor to avoid Nail Pops. This may have been solved by using barbed nails.
Re: Leveling floors
PS.....
As has been mentioned three or four times, screw the half inch plywood to the joists.
Re: Leveling floors
Experience with your situation in E. TN
Bill Tindall
I have lived in E. TN since 70's and I am familiar with home construction in this area. Quality construction houses built in the 60's and 70's had 2 x 10 yellow pine joists on 16" centers, 1/2" plywood subfloor and oak strip floor, often not finished, and covered with carpet(usually ugly). It is not rare in remodeling to take up carpet and find new oak floor beneath in these 50's-early 70's houses. Ditto for where my daughter lives in E. KY. Cheap constructed houses had western "white wood" (SPF) joists, sometimes 2 x 8", and 1/2 particle board subfloor and cheaper carpet. I built a 1300 sqft house in 1970, oak floors throughout, Pella Windows, full basement and brick siding for $21000. Code and inspectors, other than electrical, didn't exist here which enabled less expensive construction and bureaucracy.
I have never encountered any problem with an oak strip floor nailed perpendicular to the joists over 1/2" plywood. There are tens of thousands of houses here made this way, as you have discovered.
It was common in the day to be sure the floor was nailed at every joist with long nails of one kind or another. The nail penetrated the oak, plywood and into the joist. Long flooring nails will be fine from the flooring nailer, but in that day there was a spiral flooring nail with a small head that was used, and before that cut nails.
Furthermore, it is unnecessary to additionally screw down this plywood unless there are loose parts. In this time period coated nails were used. You can not remove a sheet of this plywood without destroying it. You can not pull the nails out of the yellow pine. The nail head will pull through first.
As far as leveling I would figure out why it is sagging. How much is it sagging. If it is an inch across the space of a room forget it. If it is a lot there is an engineering problem that needs fixing.
I am not a fan of wood floors in a kitchen unless it is a show kitchen that doesn't get anything close to the use ours do. The isn't a finish made that will hold up to repeated mopping and scrubbing. The floor will open cracks in the winter. All the stuff that gets spilled on a kitchen floor will accumulate in these cracks. Yuck!
Re: Leveling floors
Re: Leveling floors
I have used the floor leveling compound in my OLD (1880's) house in Indiana. I would first check to see if the "dip" is caused by something that needs correction - cracked joist, rot etc. If it is just normal settling (mine sure was cause the low spot was over a hand hewn 10 X 16 beam in perfect condition that had warped after drying). Careful when you purchase the floor leveling compound as there are at least a couple of types - some are "self leveling" some are not. As has been mentioned the self leveling may require some help. I used a float board with level worked out fine.
Re: Leveling floors
Re: Leveling floors
JMOHNIKE
What would be wrong with removing the 1/2 sub-floor and replaceing it with3/4-1" material, and shim to remove the dip. Would also allow you to inspect other areas which may need attention.
Re: Leveling floors
Re: Experience with your situation in E. TN
Bill, I am working on a house built in 1973. Has 5/8" T&G plywood nailed to the SYP joists with 8d cement coated sinkers. The plywood is so loose it rattles. Not everywhere, but we will have to do a significant amount of work to screw it down. I generally agree with you about the nails, but in this case, not so much. I am wondering what happened. The house has a basement and has been damp for a long time. Could that have been it?
It's a shame they did not glue it. Just did one with glued plywood built in 93. We had to remove 400 sf because it was soaked in dog pee. It was a bear of a job. Cut the plywood between the joists and tore it out in little chunks and then had to chisel off the tops of the joists.
I only suggest to Lynn she screw the floor down "where necessary" Its easy and fast to do now and she will curse herself later if she doesn't and wishes she had. Couldn't hurt. (If you don't want your pants to fall down, where a belt AND suspenders.
Re: Leveling floors
Bill Tindall
"Furthermore, it is unnecessary to additionally screw down this plywood unless there are loose parts".....is what I said, which seems to be what you said.
Cement coated nails are not the kind of nail I find in use for nailing subfloor. Rather coated nails are used, the kind that appear to have been lacquered. Except it is not lacquer. Rather, it is a hot melt adhesive. The friction from driving melts the coating which then rehardens and forms a bond to the wood.
Re: Leveling floors
Ah-ha......
Are these air driven nails? I have used them and they do hold well, but I don't think hand driving the would generate enough friction/heat to activate the "glue".
