epoxy food safety
Howard
I have a cutting board that split in half. Would it be safe to repair the joint with epoxy such as West brand?
I have not seen much about expoxy related to food safety.
Thanks
Howard
epoxy food safety
Howard
Thanks
Howard
Why?
Bill Tindall
Why would you think of gluing the board back using epoxy and not a common wood glue known to work on wood, resulting in a bond stronger than wood and known to last decades or centuries?
Make a clean surface to be joined, coat with what ever wood glue you have handy and clamp it back together.
BTW, where does this chemical paranoia come from? A glue joint is barely visible in width. How often would something get contacted with it? How could any significant concentration of anything transfer from a wood joint to food to body? Now compare this infinitesimal exposure to the exposure doing the gluing. If you didn't die from making the joint there is nothing to be concerned about from the cured stuff which is vastly less exposure, less soluble, volatile, reactive, etc.
Maybe...
Dale Lenz
Howard only has the capacity to glue the split back together and epoxy with it's gap filling properties would be a good glue for this.
Re: epoxy food safety
Fully cured epoxy should have no problems. The part 1 and part 2 in liquid form have a different story. Once they are reacted and cured out relatively few problems.
I'm with Bill though - I'd be more comfortable with another glue.
I have used two part epoxies as a lining material for goblets. Admittedly you're not cutting into a lining material - but you are drinking out of it.
Re: epoxy food safety *LINK*
Tony - Memphis
Ernie Conover recently wrote and article about this very subject...
http://www.woodworkersjournal.com/Main/Articles/System_Three_Clear_Coat_Finish_9167.aspx
If you are concerned, it might be worth shooting an email to the System 3 folks. It would be interesting to see their reply. I haven't checked their web site, but they might have some info already posted.
Tony
I may be wrong but epoxy is just more or less plastic when it's cured. Many turners have used epoxy for goblets and I have a friend who is an expert at using it on bowls and sinks.
