A55 Smoothing Plane
OT - FM antenna other than dipole?
Anyone have any experience or recommendations?
We don't have (or want) cable. We listen to NPR most of the time (so frequency is down in the lower part of the FM spectrum). I had used the back of the china cabinet to hold the dipole antenna. Lost that capability when we move the china cabinet to the other room.
Would like to have a small antenna that might be put on the CD shelves.
If push comes to shove, I could pin the dipole to the wall - just like at college :D - but I would really rather not do that.
Re: OT - FM antenna other than dipole?
John McGaw (Bodger)
Terk made some really good FM antennas but I haven't looked at their line for a while. Of course the best way to do it is to put up an outdoor antenna, even a simple one, which will usually provide better results than even the best indoor ones. Another thought: do you have an attic? If so you could probably string up a dipole there since normal home construction doesn't really affect radio frequencies in that sort of range.
I'd have to fish line through the walls from the 2nd floor down to the first, so I'm somewhat reluctant. Also, I have a metal roof - I'm presuming that might cause some problems - unless I could make the roof my antenna....
Stuart Johnson
I'm watching this one to see if there is a good solution. My shop is a metal building and reception is hit or miss. One day a station will come in nice and clear and the next only static.
John McGaw (Bodger)
Yep, metal roof would almost certainly be a signal killer in the attic. The other alternative might be going straight outside then. This can be easy or difficult (sometimes nearly impossible to be honest) and like most things there are special skills that help and special tools that make things easier. With normal house framing I've always managed to get cables where I have wanted. Even difficult office construction has yielded to persistent effort and I've pulled tens of thousands of feet of cable in both.
Another thought: there used to be readily available flat cable which resembled packaging tape with copper conductors. This material was so thin that it could be run on a wall and then painted over. I'll bet that someone with sufficient motivation could make their own dipole from that and then camouflage it. Then again, with a wife in the equation that might not work...
Mark
Have you tried You tube?
I know there is a growing interest in OTA( over the air ) antennas that can pick up digital TV signals now that most broadcasters if not all have switched to digital signals ..you might find a video that shows you how to build a better FM antenna, maybe the same with different spacing..don't know I am not an expert on signal waves . Some of the TV OTA ones I have seen on youtube are pretty basic DIY versions and quite cost effective using basic, easy to find hardware store materials.
An off the wall suggestion......
Merle
JL,
Use your computer or smart phone to listen to anything available on the web. Do a Google search on this phrase: "play radio station from computer" HTH
John McGaw (Bodger)
Actually, online might be a good idea but not necessarily just for finding ideas about antenna. Many of the public radio stations in the US stream their programming online. If one has always-on internet access (not always so in very rural areas) then listening is as easy as clicking a link.
Re: An off the wall suggestion......
Bruce, a MN Galoot
we use iTunes and ship it out to remote speakers throughout the house with an Apple AirPort. There probably are cheaper wifi hubs and receivers, but it works very well. Then you can install a remote app on your smart phone or iPad or tablet and control it from there. The number of radio stations available on iTunes is staggering.
I do this...
When I'm at the playhouse. I either fire up Pandora or go to the WCQS or WABE websites. But I have a perfectly good stereo with decent speakers at home.
I am not a Luddite. I actually have some technology (laptop, desktop, e reader, etc.).
del schisler
go here and i am sure you will find a way I am a ham radio operator so i know about antenns
http://www.google.com/#sclient=psy-ab&hl=en&tbo=d&site=&source=hp&q=building+a+fm+antenna&oq=building+a+fm+antenna&gs_l=hp.3..0j0i8i30l3.223.9869.0.10837.21.16.0.5.5.0.389.4771.2-10j6.16.0.les%3B..0.0...1c.1.h4YVYgTdyfU&pbx=1&bav=on.2,or.r_gc.r_pw.&fp=4a7216b9b48d425&bpcl=38625945&biw=970&bih=542
