Completed stairs - not fine woodworking (JIT)
The stringers are spruce 1 x 12" x 16'. The treads are 5/4 SYP that I ripped to depth (they were 11" + wide) and crosscut to length. The risers are 1/4" plywood leftovers from bookcase backs and other projects.
The previous owners has put pine flooring on the steps. It looked ugly. They left some sizable gaps and when it was stained and finished, I think they used a roller as there were stains on the wall.
Anyway, I painted first (big adventure). Tore out the stairs, made and installed the skirting, installed the risers and then the treads. I'm going to eventually do the railing (either new or sanding and refinishing).
Re: Completed stairs - not fine woodworking (JIT)
looks great
Bill Tindall
That job is a lot harder than fitting drawers in a case.
A molding on top of the skirt edge will add a touch of class.
That's a right fine job!
Looks good to me. I would be a little concerned about the 1/4" thick risers. I tend to hit them with my heal on the way down. Is there any backing behind them? The molding Bill mentioned is called Scotia Molding. (I think) You could add it if there is enough overhang on the front behind the nosing. If you don't kick the risers, you are good to go.
The stairs were roughed in for carpet. The existing treads are 2 x. I didn't take off the risers, but they feel to be 1 x. I just nailed to those.
