home built CNC milling machine question
Bill Tindall
I got the following note from son in law. Does anyone know where to find this information?
"For several years now, I've been interested in small/medium
home built 3 (or 4) axis CNC machines. There are LOTS of kits out there
with what seems to be endless information on accuracy, upgrades and
suggestions. I don't know anyone that has one of these to ask questions and
get an idea of what I really need. I know I would like to be able to wood,
plastic and at least aluminum. Probably looking for something that can
handle stock at least 24" wide, 36" long and 12' high. I thought I would
ask if you have any information about this type of equipment or know anyone that does?"
Re: home built CNC milling machine question
cnczone.com is the place to research
I've looked into it some...
John in NM
Definitely check out cnczone.com
My impression is that machines that cut aluminum have to be significantly more robust than those used for plastic and wood. I would imagine that you could do it on a wood machine though, if care were taken to keep the cuts very light.
What I have found is that software is the biggest hurdle, at least for me. I prefer open source stuff, being cheap, and that limits options further. There seems to be quite a bit of windows stuff around, lots of variable reviews on anything close to affordable, and all with a pretty steep learning curve regardless of platform.
I'm still considering a machine to do some of my grip carving, and that could explain my software hang up - true 3d is pretty tricky to model compared to 2 or 2.5 that a lot of the online discussions seem to be concerned with.
