joining 4 x 4
joining 4 x 4
joining 4 x 4
eliot d
What method would you use to obtain the strongest possible joint for two 4 x 4 inch posts at right angles? Aesthetics is not a concern. Even bolts, etc. would be all right .
Re: joining 4 x 4
Re: joining 4 x 4
don stephan
Can you provide some context? Are they used to support a load, is there a force trying to pull them apart, will they both be horizontal, can bracing be added to the sides?
Re: joining 4 x 4
Re: joining 4 x 4
John McGaw (Bodger)
Well, if aesthetics isn't a big deal then you could always use 1/4"-thick steel plates in a "T" shape and perhaps 8" wide by 8" high. If racking forces are a concern then the shape could be strengthened by gussets on either side. Put one of these on each face and fasten through with perhaps five 1/2" bolts with lock washers and nuts (three across the top and two down). This or a variation is used commonly in rough timber framing. Bigger timbers = bigger plates and bolts.
Re: joining 4 x 4
without knowing anything more
Bruce, a MN Galoot
I would cut a half-lap joint and bolt them together with half-inch carriage bolts with big washers.
Re: joining 4 x 4
Re: joining 4 x 4
eliot d
Sorry, I should have said more. I will be making a simple rectangular frame, about two feet wide by 1 1/2 feet high. Picture a short "superman" weight lifter with his feet on the lower two foot leg, his hands over his head pushing up on the upper two foot leg, and he exerts about a ton of force between these frame parts. So the joints I'm worried about are the four corners and I don't want them to break. (I'm actually making a kind of press.)
Re: joining 4 x 4
Re: joining 4 x 4
eliot d
Would this be stronger, do you think, than glued-up finger joints that go all the way through?(at the four corners)
Re: joining 4 x 4
Re: joining 4 x 4 *LINK*
You can get various steel plates welded into the right shape for any number of joint configurations at contractor's lumberyards. The manufacturer of choice around here is Simpson StrongTie; it's a national dealer, and even Home Despot sells them. I've linked their website below.
http://www.strongtie.com/
Re: joining 4 x 4
Re: joining 4 x 4
I would use a saddle joint. I don't think you will have much luck gluing a 4X4, but I was thinking of a treated one that would be wet. You could glue the joints in a nicely cut joints in a dry 4X4.
Or, you could cut mortises in the verticals and let them run past the horizontals.
Or, why use 4x4's? If you are building a press frame, why not use 2x4's or 2x6's and laminate three layers with alternating corners and bolt them up? A lot easier than cutting fancy joints.
Or, you could buy a sheet of plywood and cut it into matching rectangles. Cut a hole out of each one and laminate the frames together. No corner joints that way.
Re: joining 4 x 4
Re: joining 4 x 4
John McGaw (Bodger)
The answer I gave was before the more complete description you gave -- I was answering for a single crossmember supported by a single post as in building construction. If you are making a small rectangular frame then my method would be overkill. I guess that one could adapt it and substitute "L" brackets easily enough but if the materials are available then two long threaded rods of perhaps 3/4" diameter combined with large washers and nuts between two cross-beams would provide maximal strength under tension which seems to be your aim.
Re: joining 4 x 4
Re: without knowing anything more
eliot d
Do you think the extra trouble of cutting mitered half lap joints would be worth the somewhat increased twisting strength?
Re: joining 4 x 4
Bruce, a MN Galoot
In my version of your frame, I would have the vertical members extend past the horizontal members so that the wood joint itself would provide both racking and shear resistance to the vertical load. If you aren't going to do that, then the resistance to vertical load relies on the bolts alone. I wouldn't miter a half-lap joint if the primary concern is to be strength.
Take another look at Barry Irby's response, where he suggests laminating your frame. Go to Matthias Wandel's website and take a look at how he built a wooden bandsaw frame - the racking resistance of the laminated frame is impressive. It should be strong enough for whatever you have in mind.
Matt Wandel's bandsaw frame
Re: joining 4 x 4
Re: joining 4 x 4
Matthew Bruns
If its a 4X4 post to a 4X4 beam carrying a rood load, use Simpson PC44 and you can use a Simpson PB44 at the base.
If you want aesthetics, use the black iron T-straps by simpson.
You could counterbore some holes 1-1/2" into top and then drill a pilot hole for some hidden 8" longX1/2" lag bolts and socket sink them as well.
Depends on the situation and the required detailing.
