Finishing the inside of garage?
Charles Jackson III
Do you need to need to finish the inside of a garage workshop? With Drywall and Insulation.
Re: Finishing the inside of garage?
I would probably use insulation - I don't know about drywall though.
I used 1/2" plywood on my shop walls. I know of others who have used plywood also, but thicker. You've got the ability to hang many things in many places with plywood - drive a screw or nail into the plywood and that's that. If cost is a factor, use thinner plywood (3/8") or lesser grade - it is a shop/garage.
Depends on what you want to do with it, If you intend to heat &/or cool it you definitely want to insulate and cover the walls. I did a lot of research and ended up dry walling mine. Reasons - Better insulation than wood - Fire resistance - ease of repair and looks. I fasten anything I want on the walls using french cleats. I built my shop with 2X6 walls & 2X8 corners so can support any load I want. Mine is fully heated and air conditioned. I keep it temperature controlled year around to protect my equipment and it is ready for use at any time. Cost of heat is less than $50 month due to super-insulation - air conditioning cost is possibly $20 / month.
John McGaw (Bodger)
Is the garage part of a dwelling or freestanding? If it is part of a dwelling then you are probably already required by code to provide some fireblock, such as drywall of the proper thickness, and air sealing to prevent possible auto exhaust migration into the living space.
Charles Jackson III
It's freestanding.
It matters where you live *LINK*
Bruce, a MN Galoot
My shop is in the garage, the garage is located in central MN, and I just forego working in the shop during the winter because the garage/shop is not insulated. It makes me crazy. We'll be moving in a couple years so it's not worth the expense to make it nice for someone else. I've learned to live with open stud bays and no warmth, or no cooling in the sweltering summers.
If your shop is in a place where you get actual winters and you want to use it, then by all means insulate and finish it. I'm planning on doing just that for my next shop, but I'm going to use something like OSB for the walls and paint them white. Then you can hang stuff wherever you want.
BTW, take a look at this shop. The heating bill will eventually be free. The owner of the shop says that his savings from solar heating will pay for the whole shop. I don't know how much better it can get.
Solar paneled shop
Re: It matters where you live
Charles Jackson III
I live in Montgomery,AL.
Me too
Tony - Memphis
Mine was built with the house, so drywall was an easy choice. I like it. It looks nice though you can't see much of it anymore. I recently added a 220 outlet just below the breaker panel and it was easy to just cut away soem drywall and then patch it back up. Hasn't been and issue hanging anything. I don't have a lot of heavy thing hanging on my walls. Anyway, it works well for me.
Tony
In Ala, you're not likely to need solar heat
Bruce, a MN Galoot
but insulation would sure be nice for the summer months. I don't have a finished ceiling in my garage, and during the summer I can really feel the heat radiating from the roof.
Re: In Ala, you're not likely to need solar heat
Charles Jackson III
Yes it would in the summer.
