Or more clearly, my wife used it on a floor while I was off on the mountain.
Their heavier finishes would probably work fine, the original sealer/finish that comes in the pour can is so thin it's not really what I like to see on a floor. At $50 or more per gallon, I simply don't see the point.
For my money, any polyurethane is the thing to use for cheap, and the fancy moisture cure urethanes is the thing to use for premium. We did a lot of floors when I was a teen, the poly from the hardware store seemed to work just fine to me.
I can think of one- it is not a durable finish. Maybe my floor philosophy differs but my idea for a floor finish is for the finish to absorb and/or repel assaults. To that end I put on an ample thickness of something hard and tough. I finished our first oak floors with the old fashioned moisture cured urethane. After 15 years of dog claws and two kids I pad sanded it and recoated and it was good as new. That is my idea of a proper floor finish.
When I look for a floor finish I seek out the test sample typically available at the store. I try to dent it with a fingernail. If I can't it passes muster.
When you were a teen the poly from the hardware store was probably moisture cured stuff because that is what was called polyurethane in that day. Then EPA decided that home owners should not be snorting volatile isocyanates use as the crosslinker and that product became hard to get. Now days anything with a urethane molecule is called polyurethane and nothing about durability can be assumed.
Pros and cons to waterlox on floor. Easier and more fool proof to apply vs. poly. Cost more, but results are superior in my opinion vs poly. Material costs are more but you eliminate steps (buffing between coats and its cost) in the finish process vs. poly. Easy to fix damaged areas without any trace vs poly. Long drying time vs poly. Needs four coats of waterlox - adds time. Suggest using satin per instructions for the last two coats - lower gloss easier to hide mistakes in sanding process. No need for stain (saves time and money) - waterlox from the can gives nice amber color. My floors have held up just as wells as a friend's floor that has prefinished hardwood, yet look way better.
I know I'm late on this but here is some info about Waterlox for floors.
It started out as a floor finish and if you go to their site, there is lots of info about using it for that application.
Their Sealer/Finish is primarily a sealer and when used for a floor application, it is only the first coat. Subsequent coats should b their Gloss or Satin. Both of these are much thicker viscosity and apply easily.
Their Waterlox Original Gloss was originally named "Gym Floor Finish". It was renamed in the 1990's as "Gloss" but it is still the same product. It's a phenolic resin varnish. Phenolic resin makes a very hard varnish that is durable and protective.
Bottom line, it's an excellent floor finish when used as they describe on thier web site.
