pressure from clamps
eliot d
Let's say I clamp two flat boards together. Is there any way to figure out how much pressure( lbs/ sq inch) is exerted?
Re: pressure from clamps
Each manufacturer will have data on their clamps about a clamps rated pressure. So if you tighten a clamp fully then you would be at its full pressure rating. Without a guage, anything less than fully tight is anyone's guess. That said, does it matter? When clamping two boards, there are many other factors about how tight to apply pressure. Type of wood, thickness etc are factors. The desired result is generally the same....edges pushed together squarely without open seam.
T.
Addition and division
Add up the sum total of the clamping pressure of all the clamps you're using and divide by the surface area. Many typical woodworking clamps have reasonably-known maximum pressures, e.g., Bruce Hoadley, in Understanding Wood says that pipe clamps can exert 1,120# and F-style heavy-duty quick clamps can put out 550#.
Tony - Memphis
There have been several articles about this subject. Most of them have a table that shows typical values for each type of clamp. I would use that as a rough guess. Now, if you really want to get technical, you could measure it with a load cell or soemthing similar. There is a company out there that sells a material that measures loading and creates a graphic image (nice colors) of the loads. You can buy inexpensive load piezo cells and calibrate them and measure using a small ad board or micro. Probably lots of info like that on Google.
This article has a lot of good info...
Fine Woodworking Nov/Dec 2007 - "Get Serious About Clamping" by Roman Rabiej
Tony
Force Versus Pressure *LINK*
Rick Christopherson
With a lot of woodworkers, there is some confusion over the difference of force versus pressure, and this applies to how they wish to clamp their boards. The clamp creates an absolute force. It is only when we examine the size of the joint were the term pressure comes into play.
The pressure at the joint is the force of the clamp divided by the surface area between the boards. Most clamp manufactures will publish how much force their clamps are capable of achieving. Granted, even this information is very subjective.
I created the following video one Saturday afternoon as a woodworking forum response. It was the first time I used my camera and PremierPro software, so please be gentle.
I wonder if this will work.
Here's the video
Sent you an e-mail about your link question
Thanks Bill
Rick Christopherson
Thanks for the information Bill. I actually took it a step further and tried to add code for embedding the video itself. Much to my shock, it actually appears to have worked.
eliot d
No, it hardly matters for joining boards. Most woodworkers look at things like glue out, etc. I am working on making a kind of press used in printmaking, where the pressure is of considerable importance. I certainly know how how to figure it once I know the force exerted by the clamp(s). What I don't know is the force. (I have some old , nondescript boat makers clamps for example.) And I'm not even using clamps; I've set up some cauls with bolts and nuts. So the plot thickens.
Funny
Tony - Memphis
I used to be in the performance car parts biz. We sold lots of valve springs. All of the race car folks always referenced "spring pressure" and reported it in pounds. Drove me nuts, but I gave up.
Tony
Tony - Memphis
What if you made a disc or sqaure of known area and used it on top of a decent bathroom scale in the press?
eliot d
This would work. Why didn't I think of it?
