REAL MILK PAINT
Sick Rockwell 6 x 18" 22-201 surface planer
Pete in Holland, MI
Guys -
While planing some boards on my early 70's vintage 22-201 Rockwell planer, some growling from the feed roll mechanism resulted in loss of feed roll operation.
An autopsy into the machine yielded a worm gear from the feed roll gear box with no teeth left.
I did some reasearch and found Rockwell / Delta does not handle that gear any more. More research found an aftermarket builder of the gear, worm, and bearing rebuild kit for the whole planer for $629. Another site yielded only the gear and worm for about $500.
Are there any other places to find a new gear at a lesser price, either new or used ? I'm not ready to drop this kind of money in this ole machine.
Thanks for advance in your help !
Pete
Re: Sick Rockwell 6 x 18" 22-201 surface planer
You need OWWM *LINK*
or Old Woodworking Machines, a site that focuses on just what it sounds like (threshold is 25 years old or older). Link below. Ask the question on the OWWM forum, and post a want to buy on the buy/sell forum (BOYD, Bring Out Your Dead - the originator of the site's clearly a Monty Python fan).
http://owwm.org
Take some measurements... *LINK*
John in NM
Diameters, bores, pitch. You may be able to fudge a bit on the pitch, but the diameters and bore sizes will probably have to be exact.
One place to look is McMaster Carr
McMaster Carr
Robert Lemon
try Rush Gears Inc. http://www.powertransmission.com/copage/549_Rush-Gears-Inc/
Rick L
Re: Other thoughts...
Rick L
I have the same planer and it's a great machine es[ecially on curly woods with the low feed rate. I changed the worm gears 20 years when Delta still had them. Running out of gear oil is the cause. I've always thought if it happened again I was going to adapt a gear box in place of the worm gears but I'm diligent about keeping the gear oil level up. www.surpluscenter.com is a good source of cheap gear boxes. You'll have to calculate the ratio from the worm gears to find a suitable match.
You have the links to those worm gear source you mentioned? Just curious to check them out.
