I would like to thin Mylands lacquer. Can I use denatured alcohol, lacquer thinner? I believe that not all lacquer thinners contain denatured alcohol, is that true? I can not find the Mylands cellulose thinner.
Thank you
Re: Thining mylands lacquer with denatured alcohol
Dick Coers
I didn't know that any lacquer ever contained denatured alcohol. I'd be shocked that they did since there is a fair amount of water in denatured alcohol, and that surely doesn't mix with lacquer. Use high grade lacquer thinner from an auto paint or commercial finish supplier, not something from the home center.
i use only M.L.CAMPBELL product's only and nothing from the box store's, the thinner may not be refined as much as the better stuff Now M.L.CAMPBELL is owned by sherman william's M.L.CAMPBELL make's their own stuff, i would use sherman william's if you can't find the other both are better than box store stuff my 2 cent's oh i been using the M.L.CAMPBELL for 6 yrs or so maybe longer and never anything but good result's. I use HLVP with a 2 mm nozel and 30 lbs of air that work's for me, i thin maybe 10 percent sometime's.
Howard Acheson
There is no one formula for lacquer thinner. Most of the cheap ones have a high volume of alcohol and some other components. Top grade lacquer thinner used by automotive applicators will also contain some small amount of alcohol along with some other chemicals.
For the most consistent product, go to your local auto finishes supplier. Or, use the product sold as compatible by the lacquer formulator.
