DW 735 planer update
Bill Leffingwell
Two months ago I purchased a 735 based on several folks recommendation and so far am pleased overall. I also got the extension table which are really necessary.My only real complaint is the tables bolt/spring/nut assembly,awkward installation and the nuts sometimes come loose.A simple fix is to replace them with 5/16 dowel rod pins which work fine with a little trimming.As for the operation overall I am very pleased.Snipe is not a problem after raising the in/out feed tables a bit and occasionally putting pressure on the board going in and coming out.T If there is snipe it is so minor it sands out easily.Noise level is not as loud a some other units.Dust collection works perfectly(no clogs) with a shop vac.I have planed 125+ b/f of hardwoods mainly ash,oak,hickory and maple.The results are as good now as on day one.. The 2 speed is nice I generally use high RPM on the last pass or two.The overall layout is good.I have not changed blades yet.but it looks like it will be trouble free.Based on my use so far I would say it is a winner.When I do resharpen my throw away blades I will post the results(good or bad)I live in Richwood WV we had 29" of wet snow over Halloween.I hope this isn't a indication of whats to come!!
Bill
Re: DW 735 planer update
GolfSteve in Calgary
I love mine, but have never felt the need for the auxiliary tables. I've planed 8' long boards with minimal snipe without the tables. At most 2-3 strokes with a handplane removes any snipe and planer ripples.
Chip collection is efficient, blade changes are simple, but it is noisy.
