portable belt sander
Lynn Reedy
I need to buy a very good portable belt sander. I am looking for a 3 or 4 inch wide belt.
This sander will receive some very heavy work load, finishing new red oak flooring in my house.
Anyone have a good or bad experience with any brand sander they want to share?
Thanks for the help...
Re: portable belt sander
Floor sanding? w/ portable belt sander?
Henry (Raleigh, NC)
No recommendations - except I am hoping you have access to a floor sander, a drum, or even better a pad sander. Please assure me that you are not going to tackle a whole floor with 3 or 4" belt sander. That's why rental places rent equipment - to use when you need the right tools. Or are you needing to supplement a big sander with a hand sander to do edges?
Sorry I am no help here - except from your brief description, I hope I was getting the wrong idea.
Henry
Re: portable belt sander *LINK*
+1 on what Henry said. A portable belt sander is good for edges. If you were to do an entire floor with a portable, you'd have very sore knees.
A drum or pad sander is the preferred tool - see the link,
u-sand
Not the route I would recommend
Bill Tindall
Get a floor scraper from Lee Valley, or flea market, and scrape it. If you learn to sharpen the scraper properly it will mow off shaving like a plane.
And, scraped floors are high toned now days.
Makita 4x24
Mark Hennebury
Makita 4x24" I have used mine for probaly 20 years or more; Great sander!
The 4" x 24" has a good size flat surface making it nice stable. It has a lot of power and should handle the job.
Re: Makita 4x24
Dave Nichols
I did a floor which was about 12'x13' with a 3x24 Makita belt sander many years ago. It turned out fine but I sure wouldn't do it now, my knees would be so sore I couldn't stand up anymore.
George Colonel
Good Afternoon Lynn,
I echo the advice for renting a wide belt sander for bulk of floor area. Borders are better left to the handheld portable jobs, and aside from the Makita, I like Porter Cable.
George
Let me add......
Howard Acheson
....that a portable belt sander will not do a good enough job if you plan to stain the floor before clear coating. It just will not get all the prior finish from the deep pores in the wood. Any residual prior finish will cause the stain to be absorbed unevenly and therefore, color unevenly.
Rent a real floor sander. It will be easier on you and do a much better and faster job.
Jim Dillon
Lynn,
I used a Bosch 4-inch wide portable with fixed frame (to keep it level) to sand the hardwood floors in our cabin. Each room had a different species, including locust, wormy oak, and heartwood pine. It is indeed a laborious process, not to mention extremely dusty even with a shop-vac hooked to the sander. The reason I decided to use a portable was because I wanted to work on my own time-schedule over several months, and the nearest rental place was 25 miles away. Plus, most importantly, I wanted a new tool :D . After I was done, I built a stand for the sander and have a great horizontal belt sander that gets a LOT of use.
Having said that, if you have convenient access to a rental place, I agree with the others that that is the way to go.
Howard is right about the use of stain on hardwood floors. I saw a really botched stain job done by "professionals" and the sight was not pretty. I used polyurethane which is much more forgiving. I also used knee pads and didn't have a problem. Be sure to wear a dust mask regardless of the method you finally decide upon. And try to isolate the rooms with plastic sheeting of some sort to contain the dust to just the room you are sanding.
Oh yes, the Bosch is a real workhorse that is still going strong 17 years later.
My 2 cents.
Jim
