Veritas - Innovation in Tools
Bandsaw blade tensioner
alan
I have a 14" Delta bandsaw and am close to cross threading my second tensioner rod in the last 10 years. Am thinking about getting a Carter quick release bandsaw blade tension toggle, should reduce the potential for cross threading plus be a quicker approach to tensioning. Anyone have experience and opinions on this or other quick tensioners?
Thanks
Alan
Re: Bandsaw blade tensioner
Alan in Little Washington (NC)
I can't speak to the Carter, but a few years ago I replaced the standard rig on my Delta that did not have a release lever with OEM lever parts for the newer model. Parts included a new cast iron upper frame, cam lever and a few other small parts. I haven't checked the prices for the parts recently, but the parts for my OEM quick release tensioner cost about half what the Carter cost.
I have the Carter; I like it. Quick install, good directions. Mine's on a Jet bandsaw, but I believe the installation is the same on the Delta.
Jim Dillon
Alan,
I have the Carter on my 14-inch Delta bandsaw (with riser) and like it. A bit pricey though. Would I buy it again? Yes.
Jim
Question
John in NM
Why is the tensioning mechanism wearing out? No reason it should really.
My delta 18 yrs Still good, use every day
del schisler
i clean and oil all the time and it hasn't so far gave me any bad time.
The original and still good, I loosen it every time and i use it most every day for resawing ect. I would say if you never oil it that could help it go bad??
Jason Waters
How can the cost be so cheap including the upper casting?
Jason Waters
I made one out of threaded rod, and a handwheel and spinner from Harbor Freight.
A Canadian woodworker contacted the Delta factory to verify the new upper casting and parts would fit his older saw (they did!). I have no idea what the parts cost today but as you can see from the receipt he sent me it cost him $89 CDN for the parts and with shipping and tax the total was only $103 in 2004. I am certain I paid less in US $ for the parts and likely less in tax and shipping to Virginia, but I can't find my receipt. (if my math and web search are correct, $89 CDN equaled $67 USD in March 2004). I have a Delta model 28-254, 14" (Platinum Edition) purchased in Oct 2000. I think the upper casting for the 14" hasn't changed much over time. It is worth checking out.
Here is a photo of and receipt for the six parts needed:
Re: My delta 18 yrs Still good, use every day
alan
I haven't been oiling it, so maybe that is the problem. I don't know why this happens, but after around 7 or 8 years of use it starts to get more difficult to crank and ends up cross threaded. It's still usable at the moment, but getting worse. I like the idea of the quick release anyway so will probably go that route. Thanks for all the replies
Bayward
My Powermatic 14" bandsaw came from Powermatic with a Carter quick release. I would not have gone out and bought one because of the price but I sure do like it being on my saw.
Do not ask how many times I have started sawing without lifting the Carter arm and putting tension on the blade. Geez, the Carter handle is right in my face when I stand in front of the saw.
Bob
Brian
I am mostly impressed that he could find a receipt from 2004. I'm glad to find my saw in the shop!! I bet his shop is clean too.
Brian
