I need to make a light box to illuminate a stained-glass type of image in a frame. The box will hang on a wall.
My idea is to have a white inside back to the box to reflect light from leds, with the leds shielded so they don't shine directly on the image. I'm planning ventilation for the lights.
What leds should I use?
How should I attach the box to the finished frame?
One issue you'll have with LED's is that they are very directional (ie a narrow angle of light). For some projects I use some 360° LED's. I think they are coated inside to disperse the light. They are more expensive, but they work much better. I buy all of mine from an online source called superbrightleds.com. There are some good calculators online for figuring out how much resistor you need. I doubt you will need to venht. These thinks consume very little power and are pretty efficient. Sounds like a neat project. Post a pic when you are done.
My suggestion is that you don't overthink the project. You can buy prefabricated LED strips with adhesive backing from various sellers (I recommend Amazon) along with the proper UL approved power supplies, connectors, dimmers, etc and the prices are quite reasonable. For high intensity you might like:
If you mount the strips to a narrow piece of molding facing the inside of the box and the back surface is flat white you should achieve pretty good diffusion and even lighting as long as the overall size isn't too large. There are standard-density strips too but I like the high-density for most purposes.
the frame. LEDS are highly directional and the white versions are in the blue/white color spectrum. Once you get them you will have to check if they show your piece well uncorrected for color. One or two finish nail sized holes are all you will need for venting and that is mostly to keep the air inside the box the same as the outside to eliminate moisture. You will need to break up the directionality of the light to avoid shadows. An inexpensive way to do that is to bounce the light using crumpled aluminum foil or crumpled mirrored mylar. A thin piece of white plexiglas within the frame set in before the stained glass will further smooth out the light, and using LEDS you won't have to worry about burning the plexi. If you have an IKEA close, they have strips that are inexpensive, but as has been pointed out there are many choices on the net. Remember locating the transformer will be a part of the mix.
