Re: Finish for stair treads - when and which type?
Phil lieberman
I would go with Varathane semi-gloss or satin (Oil) because gloss will show any wear/imperfection fast .I just flipped a "Condo" after redoing the building and i refinished the flooring and used this product and when i redo my Oak flooring in my house i will use it. it costs more than the rest. I think its says on the can for High traffic finish
Keith Newton
I wouldn't do gloss either. And a nice touch, is to mask off about a 2" strip, back about 1" from the nose. You can get some non-skid powder which you sprinkle into a wet coat of finish, or epoxy, which helps with traction, especially with sock feet, or wet shoes. It doesn't hurt the aesthetic appearance either.
For sure, there's nothing wrong with SYP stair treads. However, poly may not be your best choice for a finish, only because of its long term repairability issues. You might want to consider Waterlox instead. It might not be quite as tough as poly, but when it finally needs to be renewed, it's a lot easier to apply a new coat.
Yeah, poly is cheaper, and tough enough, but if it's your own home, you have to consider the maintenance costs over time.
