A55 Smoothing Plane
Sidewalk Sandwich Board with Chalkboard Paint?
don stephan
Myself and two nearby businesses would like to make matching sidewalk sandwich boards to encourage drive by traffic to stop. And we'd like to be able to write on the boards with chalk. Has anyone used any of the brands of chalkboard paint for exterior projects, and if so which brand(s) and substrate? I'm thinking of using MDO plywood for its smooth surface and what I believe is good weather resistance. Thanks.
Re: Sidewalk Sandwich Board with Chalkboard Paint?
I used Rustoleum Black Flat Chalkboard paint for a set in a play. Worked great. It was not outside - but it worked great.
I had it on a smooth piece of lauan plywood.
Rick L
Rick L
It will fine. I put a piece of crystal clear plastic fastened at the top as a curtain to keep the rain and snow off. I've used that bathroom white surface as a whiteboard and did the plastic curtain. I found the whiteboard markers showed up better .
Jason Roehl in Lafayette, IN
Read the labels.
Or call the manufacturers. That's the only way to know for sure if a particular chalkboard paint product is rated for exterior use.
Or try to find some actual chalkboard to cut and use for the panels.
Jason
Galen Vetterick
I assume you have checked to see if it violates any city ordinances to post any sidewalk sandwich boards? Can you get a permit and will it be only temporary for special city or local functions? Any restrictions on size and time of day it can be posted? Hate to see the time and material invested if the city kills the idea even if you think it is good.
Just thinking how my city works.
Our local Ace hardware is now carrying chalkboard cloth that you can glue on. Not sure if it's any more/less weather-resistant than the paint.
Prep your surface well, even more obsessively than with regular paint; I did chalkboard paint on a kid's easel when I was a newish parent, and it was so lumpy (due to my inexperienced incompetence) that it was unusable as a chalkboard.
most use liquid chalk markers.......
Dick Coers
these days, and they need a smooth surface to write on. You could laminate a piece of black high pressure laminate to the MDO and that should last a long time.
Howard Acheson
Be sure to completely seal the edges if you want the panels to last. Water that gets down into the plies will cause the panels to delaminate.
