Klingspore Woodworking Extravaganza
Alan in Little Washington (NC)
As I mentioned in Ellis's Ad post I attended the Klingspore Woodworking Extravaganza last weekend in Hickory, NC. I was representing North Carolina Woodworker dot net and did a demonstration about box joints and the INCRA I-BOX jig for box joints.
The show, though not as big as the traveling Woodworking Shows, was still nice- just about the right size for me. In addition to booths representing most of the major manufacturers, there were a lot of demos and hands-on opportunities provided by woodworking guilds and clubs across North Carolina.
My demos went very well- the I-BOX made me look like I actually knew what I was doing. I had a combination of completed box joints and joints in progress, supplemented by joints I made during each demonstration: Here is a report of my last demo of the show:
I felt a bit rushed because the NCWW booth was a little small which forced us to do a major reset between each demo- move a lathe to the back and the tablesaw to the front, etc., change the setup and swap out all samples, etc. My time was especially short since the preceding demo ran over its allotted time, so I decided to forgo some of the simpler decorative joints and go straight from making a basic box joint with MDF to making the most elaborate joint possible with the I-BOX, the center-keyed splined joint using some good hardwood- walnut, maple and another hardwood. I quickly checked the I-BOX calibration and verified the pin spacing matched the (3/8") blade kerf- it was really .368" (vs .375"). This joint requires a micro adjustment equal to half the kerf width. So to make it easy to dial in .184", I used a mix of fractions and decimal micro (I-BOX micro is 1/32" per rotation and .001" per tic mark). I very quickly rotated the micro dial 6 full rotations (almost lost count!) for 6/32" (.1875" ) of micro then backed off, a tad over 3 tic marks for the desired .184" of micro.
Unlike a standard joint where you cut from edge to the other, this one requires you start from each edge and work towards the center of each piece. I quickly made the cuts in each board, then, without changing any of the settings (the beauty of the I-BOX when making this joint) I used the I-BOX to cut the decorative splines- another set of fingers made from a contrasting colored wood. The guys had already put the bandsaw away so I had to cross cut the spline strip using the dado blade! Once cut, I snapped off a few finger sets, and proceeded to dry assemble A PERFECT JOINT!! - a perfect end to a very satisfying weekend!! I had to leave early, but when I checked the Klingspore sales area before leaving, they had sold almost all the I-BOXes they brought to the show!!
I didn't have a camera and it seems pictures weren't taken of my demos or static display, so I shot some photos of the my visual aids earlier today. All samples were made with a standard I-BOX, neither Photoshop nor smoke & mirrors were used: :D
My demo/display sign:
Splined Joint- Walnut with aluminum splines!:
Splined Joint- Beech w/Walnut splines:
Dentil Molding in Walnut made with three different sizes of dentils:
Dry-fit Splined Joint in MDF (untrimmed splines). Show attendees could disassemble, examine, and reassemble this joint and others like it:
A dry-fit, Center-Keyed, Splined Joint in Poplar. The Walnut splines were cut with the I-BOX using the exact same settings used to cut the joint. Splines look like this when trimmed from the spline material with a bandsaw, but have not been glued nor trimmed flush:
Dry-fit, Center-Keyed, Splined Joint in Poplar (trimmed Walnut splines):
Another dry-fit, Center-Keyed, Splined Joint in Walnut and Maple. Though extremely rushed at the time, I made this perfect fitting joint during one of my live demonstrations. Once glued, trimmed and sanded, this joint will look great though it probably would look better if the splines were purple heart or blood wood!
One of six sets of joints made with different amounts of micro adjustment. They clearly illustrate how critical the fit is for a box joint. I intentionally added different amounts of micro adjustment to each joint. The amount ranged from - .004" which resulted in a joint that was too tight to + .006" which resulted in one that was too loose. I asked attendees to assemble each pair so they could feel the difference for themselves. With the I-BOX it is easy to make perfect joints at the outset or to correct the joint if a test shows it is less than perfect:
These two joints, cut in opposite ends of the same boards using exactly the same I-BOX setup, show how using the Center-Keyed technique can eliminate partial pins at the edges of a joint- it moves the "widow" finger material to the center of the joint. I had attendees watch me assemble the "widow" end first and pointed to the "widow." Then I assembled the Center-keyed end and asked them what happened to the "widow." Fewer than a half noticed the wider center (maple) finger!!:
Note, the narrow Walnut finger ("widow") at the bottom of the joint:
Not always possible due to board width and cutter size, the Center-Keyed technique normally results in full sized first and last fingers, a symmetrical joint, and eliminates the "widow" by moving the extra material to the center of the joint. When combined with various versions of the Splined Joint, it results in some very unique looking joints:
Re: Klingspore Woodworking Extravaganza
Phil lieberman
Great post Alan,, Wish i had known i would have come to that show Hickory NC is really not to far from me here..its been some time
