Relighting the shop
Relighting the shop
Relighting the shop
Bill Tindall
Background: my shop lighting is a product of 20 years of evolution with the goal of getting 200 ft candles in the vise area where I do detailed work like sawing dovetails. I had 14- 4' T8 and T12 tubes over the bench area. The new T5 HO fixtures enabled me to be rid of bunches of overhead fixtures and wind up with more light where I need it. The 4'- T5HO lamp puts out twice the light (5000 lumens) as T8 or T12.
I put one of the 4 x 4' T5HO's over the vise as recommended by brother in law the lighting engineer. It is the sun-like light over the vise in the picture. I will add a second down the bench edge later. He said the lights should be over the edge of the bench for best results. This one fixture gave me nearly 400 ft candles of illumination in this area ( a shady day outside is 500). To get light on front facing surfaces I had to install a second light (the 4' Toffer) somewhat behind me, standing at the vise. The wire on the bench is what got removed along with 4 other fixtures.
I am also painting the ceiling white as recommended by brother in law. Tedious among all the wiring.
With this arrangement I can now saw dovetails without additional spot lights on poles.
Re: Relighting the shop
Alan Young
Very Good- I desperately need to follow your lead!
I need to do that but then I'd just see all those darned sanding scratches.
John McGaw (Bodger)
I can confirm that a white ceiling really helps. My shop is downstairs in half of a two-car garage and last spring I had both sides spray-foamed and hung 5/8" drywall to get into code compliance. Putting back the same old 8' fixtures (8 tubes in all) gave me about 20% more ambient light than I had before and I have to attribute that to the ceiling with is painted flat bright white. I still want to add at least one more fixture and even with that I probably won't have nearly the amount of light you want but when I am forced to upgrade the existing T12 lamps to the modern standard I figure that I'll be good to go.
clarification T12 , T8, T5 light output
Bill Tindall
How much light a fluorescent lamp puts out depends on its wattage, the ballast and the phosphor coating the lamp. T12 vs T8 vs T5 tells one nothing about relative light output, only the size of the tube. The T5 HO is a 54 watt lamp and it is the 54 watts coupled with an efficient ballast and phosphor that results in its high output. Electronic ballasts are more efficient. Only by reading the information on the box will you know if you are getting more or less light from a T12 of T8. And, there are vastly more options than you will find at Lowes for combinations of light output and color quality.
Bob
Bob
Wish I knew you were in the market. Here is what I did and its very good lighting and no shadows.
I got them at Home Depot there called "High Bay 6Tube and take 32 Watt T-8s 5600 Day light) Bulbs sold separately I highly recommend them
John McGaw (Bodger)
I know. When I put in the new fixture(s) I will be installing high-output T-8 rather than the standard-output T-12s which I have now. If the difference is big enough then I might go to the trouble of converting one or two of the old ones. From what I've seen converting is just about as expensive as purchasing new but I've only taken a cursory look at the market so far.
Jason Waters
I wouldn't say converting is as expensive. I bought a 4 pack of T8 ballasts for like $60 at HD. That's $15 a fixture. The fixtures I have are about $40 each.
Savings for me.
