Sanding ceilings
Sanding ceilings
Sanding ceilings
Lynn Reedy
I am soon to start remolding my kitchen and foyer. As part of this job, all the "pop corn"
on all the ceilings will be removed. Back breaking, neck breaking and all around a terrible
job to do but I am up for the task. Does anybody have any experience with any vacuum
powered ceiling sander? Need to control the dust. This is a start to doing the entire house ceilings.
What ever I get needs to be very durable. Thanks for the help..
Re: Sanding ceilings
Popcorn (at least the ceilings that I have done) ceilings can typically be scraped. If you need to sand, then a 6" ROS attached to a vacuum with a HEPA filter works reasonably well. A 5" ROS would also work.
I've usually just scraped though, a long handled scraper is a must. I also found that the small, roll around scaffolds are a very valuable tool.
There's a much easier way
Neal in San Jose
First the caution. The "popcorn" can contain asbestos if it was applied prior to the mid-'70s. I owned a house built in '63 that I had tested and the popcorn only contained a "trace", so it is not universal.
Cover everything with painters plastic sheet. I use push-pins to hold the top edge along the top of the wall and let it fall down over appliances, etc to the floor. Tape typically won't work as they use some sort of mold release on the plastic when they manufacture it which makes it slippery, but you might try it - you could get lucky. Then put a layer of plastic on the floor. Next, get a garden sprayer that has never been used with anything nasty (I usually buy a new one) and fill it with plain water. Spray the popcorn. Soak the popcorn. Spray the popcorn again. With a little luck, it will start to fall off. Use a wall paper scraper or small drywall trowel - the ones I use are about 4 - 5 inches wide at the business end - and scrape the popcorn off. Keep spraying ahead of yourself. If you want, you can catch the popcorn in a dust pan and toss it into a trash can, otherwise let it fall on the plastic on the floor.
If the popcorn has ever been painted you will need to run over it with one of those wallpaper puncturing tools - looks like a bunch of star wheels lined up on a handle - to allow the water to penetrate into the popcorn. This slows things down, but it'll still work. the secret is getting enough water into the popcorn to get it to release. It is water based, and with enough water will come off.
Now that all of the popcorn is on the floor, pull the stick pins out of the plastic and let it fall onto the floor and roll the whole mess up and stuff it into the trash can.
This won't be the most pleasant job you've ever done, but it is a lot easier and less messy than trying to sand it. You will probably sweat off 10 pounds because once you've sealed up the room with plastic and sprayed the ceiling, it will get really humid in there! Your safety glasses will constantly fog up, too.
HTH Neal (who has removed acres of the stuff using this method)
been there...done that
Bill Tindall
Do to a "miscommunication" the drywallers popcorned the ceiling in our house. They were removed from the job and I hired a crew of three people to redo the ceilings. The hideous little motel ceiling balls were readily scraped off and the ceilings redone (2500 sqft) in one day. Some ceilings were redone with a "stiple" (if that is how it is spelled?) but most done by mixing drywall mud with latex paint and rolling a texture onto the ceiling. It was the best construction money I ever spent.
How do you re-popcorn a small area
I have the opposite problem. I added an 8x8 foot dormer and had to cut through the sloped ceiling. The new ceiling of course is just painted dry wall right now. I really don't want to rent the popcorn spraying machine. I purchases some stuff that you trowel on and then roll a loose roller across it but I doubt it's going to look even close to the same. Any suggestions?
Though I don't usually recommend Harbor Freight...
John in NM
They do sell a cheap texture gun that should do acoustic if you have a decent air compressor. I found results to be mixed using one to match the knock down texture that was throughout our last house, but it was better than anything else I had tried.
Tool rentals from the likes of Home Depot are usually pretty reasonable, you might want to consider that too.
Six rooms . . .
steve mackay
. . . and still have three to go in pop-corn removal. YUP ! It sucks. SWMBO has a system though. I can't get the "hang" of it but she can do a room in a day with no sanding. She has a small "spritz" ("she"-talk for spray bottle) bottle. She DAMPENS a three by three foot section, waits a matter of seconds (the time it takes to get off the ladder and exchange "spritz" bottle for scraper) then CAREFULLY scraps it off with a three inch putty knife. It is a mess but MUCH better than sanding it off. She makes it look easy. The most sanding I do is knocking the "boogers" off that didn't fall off.
Just curious...
Merle
Wouldn't it be easier to put new drywall over (under) the existing popcorn ceiling?
