Storm
Stuart Hough
Good luck to Ellis, Bob, and all you others in the northeast! I hope the storm doesn't batter you too bad.
Storm
Stuart Hough
Re: Storm
Ralph Lipeles
I am in southern Connecticut. It took me almost a day to move everything, including quite a bit of wood, off the downstairs floors. The water vac is all set up and ready to go. The last storm, I was moving about 30 vacuum loads of water a day out of the basemant and garage. The incoming water started slowing down after the 3rd day. This storm is supposed to me worse.
Ralph Lipeles
Hey Carol, wearing your life vest?
The only thing I have done out of the ordinary
Frank Grambo
Last year after some leaves and water accumulated on the stairs and into the basement I made up a quick and easy leaf and water divert-er. I cut some short lengths of 2x4's into "drop in" rafters between the house siding and the concrete stair wall. The wall side of the rafters has a birds mouth cut into it. A 4/12 pitch is all you need
I sheathed the top surface with coraplex. It is lightweight cheap and quick to attach. The stuff is often used as sign material for political signs. The assembly can be removed in about ten minutes but it can save hours of "problems".
