I picked up a Makita 1900B hand held electric plane this weekend. The cutters were loose in the box. Installing them looks obvious. Just screw them to the carrier, drop it in place and screw down the top holding bracket. There were also a set of another style cutter in the box. These cutters are double edged, only about 3/16" wide and have a shallow groove on running along one side. Can anyone tell me how these cutters would be installed?
Ralph, I have a larger Makita which uses knives like your first description, and a DeWalt which uses the other type. I doubt they will cross over. If you got the tool second hand, maybe someone just stored the blades in the same box.
The Makita could be purchased with steel blades or with carbide inserts.
The steel blade is attached to an adjustment plate that positively locates the blade (Makita sold a little plastic setting jobbie on which you laid the blade and adjustment plate before tightening screws).
The carbide inserts slide into a separate "set plate" that clamps them in place. They're double sided so that, when one side wears out, you pull them out, reverse them, and re-insert.
I started out with the steel blades, but they got dull pretty fast. I'm still on the first edge on the carbide inserts I purchased to replace them.
The steel blades are no longer available, but the carbide inserts still are. Incidentally, the set plate for the carbide inserts resembles the steel blades quite a bit, except for its leading edge.
This is a great planer. It doesn't have chip collection, as far as I know, and the chips come out one side only (you can't change which side, in other words). If I were buying new, I'd probably get a Bosch; but since this, like so many Makita tools, seems to be immortal, I'll probably never get the chance.
I don't know the Number, but I have the long bed version of that plane. The knives appears to be identical to the ones in the pdf somebody posted for you. They are easy and quick to change. I sharpen them myself on a sharpening attachment I have on a grinder.
