Managing big glue ups
Stephen Kirk
Finally, the first bookshelf carcass is together. Everything went well. We did a full dry run and made sure we could assemble everything, clamp and close the joints within the glues working time.
I assembled the sides ahead of time. Still, getting the dividers and panels onto the back was a bit tricky. Practicing something like this is a definite must, because you don't want to have glue setting up and discover that a joint wont close. BTW, the lower front rail is dovetailed in, so there's no need to clamp there.
I know my front opening is square (corner to corner measurements were good), but I'm not sure how to determine if the whole case is square. I know the legs might have picked up some slight bow, so putting a square around it isn't very definitive. I have two more to assemble, and if there's something I can do to check for overall squareness, I'm open to suggestions. If something is a bit off, I can always "adjust" the shelves slightly when I make them.
Now that one is together, I'm happy with the look of the carcass members and the panels. I find they contrast well together. Once the finish is applied, they should look very nice. I pre-colored all the carcass pieces, and the panels will stay natural. The color is a bit darker in real life.
