use for motorcycle jack? *LINK*
Jerry Gibbs
Some years ago I was given a motorcycle/atv jack. I don't have either vehicle or anything similiar. Is there a use for such a jack in a woodworking shop? I originally thought it could be used for an adjustable assembly table, but the lift is only 12". The jack is heavy. I am undergoing a forced cleanout of the shop. If you need a picture, here is a link to a similiar jack. Jerry
http://www.grainger.com/Grainger/CRAFTSMAN-Motorcycle-Jack-12N399?gclid=COmz4_T_g7MCFQQ4nAodJDoAOw&cm_mmc=PPC:GooglePLA-_-Fleet%20and%20Vehicle%20Maintenance-_-Automotive%20Lifting%20Tools-_-12N399&ci_src=17588969&ci_sku=12N399&ef_id=TE822QqoEGMAAD50
Re: use for motorcycle jack? *LINK*
William Duffield
I have a hydraulic floor jack, which is like yours on steroids. It serves the typical functions of lifting cars and tractors. In the shop, I use it if I ever need to move my workbench (and yours would work too), to lift the bench high enough, one end at a time to get a pair of furniture dollies under it, and then to extract them at the bench's new destination. I've also used it to lift my jointer off its base. So, no not much use I've found, but you night want to look at Geoff Noden's Adjust-a-Bench for inspiration. An adjustable height assembly table would be useful.
walta
We used one this weekend to move a Stubby lathe.
So it does have a woodshop use.
Walta
http://stubbylatheusa.com/S750_Brochure.90.pdf
Bruce, a MN Galoot
I can't think of a woodworking application, but I have a similar one and it is a godsend for working on my motorcycle.
Bert Bleckwenn
I've got my son-in-law's jack that is almost identical and find it very useful for moving my fully loaded Tag Fried style workbench and large Nova Lathe (loaded with 400# of sand). I purposely try to design or buy stationary tool stands so they have enough clearance so I can use the jack. Because it only extends up ~16" when extended, I've also been considering building an extender frame/box to sit on top so I can move large turning blanks to the lathe height and bandsaw height for cutting and turning.
If I didn't have the motercy me jack available, I would have invested in one of the hydraulic style platform/table jacks.
Definitely worthwhile to keep it around or pick a used one up if you have an opportunity. Just my two cents worth.
