What to do
What to do
What to do
Mark Hennebury
Last year we had most of this big poplar tree cut down as part of the tree was dead and going to fall down anyway. The main trunk is still standing and i haven't decided what to do with it as of yet.
Any suggestions.
Re: What to do
Not a good tree for lumber
Bill Tindall
There is not going to be any top grade lumber in that trunk. It grew with few if any neighbors and therefore made limbs low on the trunk. Some may grade 1 common, but the most of it will be knotty and yield only short lengths of clear lumber. The clear short lengths are going to be near where there were limbs so these lengths will have wild grain and be unpleasant to hand plane.
Poplar makes crummy fire wood. It explodes in the fireplace.
Re: What to do
Re: Not a good tree for lumber
I agree with Bill. If you want to salvage the wood for sentimental reasons, you can and you may get some short pieces. Poplar can be versatile, but I use it for "white" wood or internal parts. If you are willing to pay to have it sawed and then dry it you may get some that is useful for interior parts. May end up being expensive as you will have to pay to saw all of it and then cull through it to get a low yield.
Re: What to do
Carving Blanks
Poplar is a little harder than basswood but is still considered a good wood for carving...if you are inclined. Maybe cut some chunks of it and dry it.
T.
Re: What to do
Mark Hennebury
What about a rustic kitchen table, something big n clunky, knots and all, just because the tree has been probably been here as long as the house. and it would be nice to keep a part of it.
Do you think its worth trying to get it cut into lumber.
I have no experience in cutting trees into lumber; I always purchased my lumber cut, dried and graded.
For all i know there could be a cast iron garden gate inside it.
Or is it bonfire material.
Re: What to do
An excellent tree for knots
Bill Tindall
If you want knots this will be the tree to use. I have not doubt it will yield FAS grade knots in abundance.
Poplar molds readily so it is important to bet the wood on !dry! sticks in good air circulation. Once the surface is dry mold will not be a problem
Re: What to do
Not that I disagree with the others,
Keith Newton
But if you had dead limbs on it last year, I would bet that most of it is too far into the decay process to be worth any time and effort, or $.
Re: What to do
Dale Lenz
Re: Not that I disagree with the others,
Dale Lenz
To check for decay wood near the surface, try poking a screw driver/ice pick in the tree, either tool should not go very far into the wood.
I would think there would be some good wood between the two sets of knot in the pictured tree.
