Preferences for porch step wood
The front porch steps needs replacing. I could go with pressure treated, but it takes so long to dry out so I can paint it.
I am probably going to have to replace the stair stringers while I'm at it. Those I don't mind being pressure treated.
Suggestions? I don't mind synthetics or "artificial wood".
Re: Preferences for porch step wood
White oak?
The longest lasting wood would be IPE - kind of expensive but would last for many years. If it is available in your area, Black locust would also be a great choice very durable and again very long lasting both from wear and decay. My third choice would be White Oak as has been mentioned.
Ron Jones
I second Larry's comments. My personal preference would be black locust due to the costs. I have seen black locust fence posts that were still rock solid after decades in the ground.
Only 3/4 ipe available
and it is kinda pricy ($3.85/linear foot for 1 x 6). I would have to space the stringers a bit closer (16" on center at a minimum).
Kneale Brownson
Are front steps the mainly used entrance?
Kneale Brownson
If so, you probably need something durable. If not, my front steps are 6/4 cedar almost 10 years old. Have only been repainted.
Re: Are front steps the mainly used entrance?
To be honest, we always come in from the garage.
The front porch steps are south facing and in the front of our house. They've seen better days.
Sassafras.....
Dennis E Peacock
I know of 2 people that have used sassafras for front porch wood decking and steps. All I know is that after 5 years of daily use, the wood was still good. The steps did show wear, but still solid.
White Oak is the original outside wood, but Aromatic Red Cedar is another great choice of exterior wood. I'd have to vote on Black Locust as well, I know of a couple of farms where they used black locust and decades later, they are still there on the porch and the steps.
Re: Only 3/4 ipe available
William Duffield
Ipe is much stiffer than any of our domestic species. It probably doesn't need to be any thicker than 3/4" to be suitable for decking. Check with your supplier (or the USDA FPL) to be sure, however.
Another vote for ipe
I replaced the floor on our veranda with ipe about six or seven years ago and it's practically bulletproof. I used the nominal 1" material, which mikes out at about 15/16". It's pricey, but it'll last 50 years, which is longer than I'm going to need it.
