Question for bruce NM Galoot
Rick Snyder
Hello Bruce,
Would you explain further on how you apply the last coat of Poly/w400 grt w/d sandpaper. I have not tried that techinque before. I use G.F. finishes for all my projects and I'm going to assume the techinque would be the same.
Thanks, Rick
Re: Question for bruce NM Galoot
Bruce, a MN Galoot
I just pour a little finish on the surface or wipe a bit on, leave it wet and sand it down with 600 w/d sandpaper. It both removes any nibs that are left and rather burnishes the surface. Then wipe the surface with a soft cloth.
It's also how I apply oil to wood, too. You won't believe how nice a finish this produces.
