Poly question
Poly question
Poly question
Jerrid Edgington
This is going to sound like a completely retarded question but I have been refinishing old furniture and I was a video on a wood working website where they used Minwax "wipe on" poly. Is there a difference between the wipe on poly and just your standard poly ?
The problem I'm having is when I apply the lacquer or poly I see alot of brush marks. I know the answer to that is to purchase a sprayer but I'm having trouble convincing the boss (my wife) that it would be a good investment even though this is more of a hobby.
Any suggestions would be greatly appreciated.
Jerrid
Re: Poly question
Re: Poly question
Jerry Roberts
Hi Jerrid. What I do, and it works really well for me, I make my own wipe on polly. I mix abt 60-40 or so with satin poly and 40 with naptha, not mineral spirits. Why is, naptha evaporates quickly and one can do many coats in a few hours. Also dont return the mixure to the original can. It doesnt work well later. Only mix as much asyou willl need to completly do the job. Good luck.
Re: Poly question
Re: Poly question
Dick Coers
Poly or Wipe on Poly are the same stuff, just thinner viscosity. Spraying poly takes a bunch of skill, and then you still get runs on vertical surfaces. I prefer to brush it. Get a really high quality brush, put on the coat, tip it off if necessary, then let it alone. If you are getting a lot of brush marks, you are going back over it too much. I prefer wipe on for my turnings. I make up a small cloth pad like I would use for padding lacquer. That way I can put on a thin film, and let it alone. It always needs a final finishing, 600 grit or finer, because of the slow drying and dust nibs. For a table top, you might need 5 or 6 coats of wipe on, 2 coats with regular poly applied with a brush.
Re: Poly question
thin it
Bill Tindall
modern finishes are formulated to meet EPA regulations not to brush easily. Thin with mineral spirits and then try brushing.
Re: Poly question
Re: Poly question
I thin my poly - but I also add a bit of boiled linseed oil or tung oil.
As far as spraying - I bought an inexpensive HVLP sprayer from Rockler a while back. I haven't regretted it yet.
Re: Poly question
Re: Poly question
Dave in Bryn Mawr
You can buy wiping poly in a can or make your own as already described. Not mentioned so far is that these coats or very thin and require 5 or 6 coats. Application is very easy - just wipe it on with a soft cloth. An option is to use poly gel varnish to get a thicker coat (also wiped on).
Re: Poly question
Re: Poly question
Bruce, a MN Galoot
Also, apply the stuff with 400 w/d sandpaper, and the final finish will be as smooth as my granddaughter's posterior.
Re: Poly question
Re: Poly question
Paul Blackwell
I've had good luck using foam brushes to apply poly. I tried a new technique the past few times. The first coat I apply normally, and after drying and sanding with 320 grit, I apply another coat and then turn the brush on it's side and using the edge of the brush, wipe across the surface to level and smooth the finish. It seems to remove all the tiny bubbles. Finish comes out much smoother.
Re: Poly question
Bob
Re: Poly question
Bob
I use wipe on poly and it works great. If your getting brush strokes cut the finish a little. If you never did a brush job before and see strokes it is most likely the method you use. Let it dry and apply 2 or 3 coats sand lite with 220 or 320 then hand rub the last coat. Am I right gang?
Re: Poly question
Go to Sally's beauty supply
Ray - Middletown, in
and get some small squeeze bottles. Mix in that and just squirt some on a soft cloth and wipe away. Goes quickly
Ray
Re: Poly question
Re: Going back to the original question
Howard Acheson
Yes. In general, wipe-on varnish is fairly highly thinned. More coats are required to build a protective finish.
You can make your own wiping varnish by mixing you favorite varnish or poly varnish 50/50 with mineral spirits.
Here is something that might help:
Here is something that should help. A friend of mine who was an early advocate, put it together years ago and it has worked well for many.
QUOTE
There are a number of suggested application regimens that are totally subjective. The number of coats in a given day, the % of cut on various coats, which coat to sand after, when to use the blade and a whole host of other practices are all minor differences between finishers. There are some things that I consider sacred when applying a wipe-on finish.
First, you can use any full strength oil based clear finish. Polyurethane varnish or non-poly varnish is fine.
If you are making your own wipe-on the mix is scientific - thin. I suggest 50/50 with mineral spirits because it is easier to type than any other ratio and easy to remember. Some finish formulators have jumped on the bandwagon and you can now get "wipe on" finish pre-mixed. If you use a pre-mixed, thinning is generally not necessary. But making your own is cheaper and you know what's in it.
The number of coats in a given day is not important. Important is to apply a wet coat with an applicator and merely get it on. Think of a 16 year old kid working as a busboy at Denny's you have sent over to wipe off a table. Sort of rub/swirl the the material on like you would if you were applying a paste wax. Don't attempt any straight strokes. The applicator should be wet but not soaked. The applicator can be a non-embossed paper towel shop towel, half a T-shirt sleeve or that one sock left after a load of washing. Once applied,leave it alone. The surface should not be glossy or wet looking and, if applied correctly, there should be no "brush stroke" type marks. If you have missed a spot, ignore it - you will get it on the next coat. If you try and fix a missed spot you will leave a mark in the finish.
Timing for a second coat involves the pinkie test. Touch the surface with your pinkie. If nothing comes off you are ready for another coat. If was tacky 5 minutes ago but not now, apply your next coat just as you applied the previous coat. Remember, you are wet wiping, not flooding. After applying the second coat, let it fully dry for 48 hours. Using 320 paper and a sanding block lightly sand the surface flat. Now, begin applying more coats. Do not sand between coats unless you have allowed more than 24 hours to elapse since the prior coat. The number of coats is not critical - there is no critical or right number to apply. For those who need a rule, four more coats on non-critical surfaces or six more coats on surfaces that will get abraded seems to work.
After your last coat has dried at least over night you will have boogers in the surface. You should not have marks in the surface because you ignored application flaws. You may have dust, lint and, if you live in Texas, bug legs. Use a utility knife blade at this point. Hold it between your thumb and forefinger, near the vertical, and gently scrape the surface. Gentle is the important word - no harder than you would scrape your face. If you start scraping aggressively you will leave small cut marks in the surface. After you have scraped to the baby butt stage gently abrade the surface with 320 dry paper or a gray ScotchBrite. Clean off the surface. Now, leave the area for two hours and change your clothes. Apply your last coat with a bit more care than the previous coats and walk away.
An anal person is going to have a tough time with this process. Missed spots have to be ignored. Wet wipe, don't flood. Scraping to babies butt smooth means scraping no harder than scraping a babies butt. Ignoring any of these will leave marks that are tough to get out. Getting these marks out requires some aggressive sanding to flatten out the surface and starting over.
Jim Kull
END QUOTE
Finally, It works better to use a gloss varnish for all coats except the last. The flatteners in semi-gloss and satin tend to rapidly fall out of suspension when the finish is highly thinned. If you want a non-gloss finish, use it only on the final coat or two and be sure to stir the material frequently or you will end up with cloudy streaks.
