Finish for Rosewood????
My son built a keepsake box for my grand daughter, his niece. He is wondering what to use for a finish. Any experience/suggestions?
Re: Finish for Rosewood????
Grant in Iowa
I have built a few small projects from Rosewood. On both, I simply sanded to 320 grit, then buffed the pieces on a buffing wheel with red rouge followed by a hand applied coat of wax. A long lasting high shine was the result, thanks to the oily and hard nature of the wood.
Some apply lacquer finish first, then buff the lacquer. I found Rosewood to be oily enough that it wasn't necessary. Lacquer first would likely contribute to a deeper looking finish, however.
If this is your first buffing project, practice on a piece of scrap first. Make sure you always work from the center of a surface towards and edge, and present the workpiece to the trailing or spinning way from you portion of the wheel.
FWIW,
I've used oil...
John in NM
Either watco or tung oil. Scarcely needed, but they work fine. Keep the oil thin though and only a couple coats. Doesn't soak in the way we're used to with other woods.
oops...
John in NM
meant to reply to Barry, sorry Grant
