A55 Smoothing Plane
Raised Panel Door/Hinges Question
Ed in NY
Hi, I've never built a raised panel door before so I want to make sure I'm doing everything correctly before I waste a lot of Oak. I'm using a raised panel door calculator to determine the wood I need to cut so I'm pretty confident about that part. The part I'm concernd about is with the hinges. I'm using 5/8" overlay hinges I got from Home Depot and I'm using a Jig-It hole cutting system to locate the hinge holes on the doors. The part I'm confused about is with the overlay. The hinges are 5/8" overlay but the Jig-It template drills the hole in one spot regardless of the type of overlay hinge you buy. Does the hinge itself determine the overlay and not where you drill the hole in the door? Are all door hinge holes drilled in a standard location? Thanks!
Re: Raised Panel Door/Hinges Question
It would help if you gave mor hinge info.
Keith Newton
I tahe it that you are using Euro concealed hinges. If that is correct, yes the hinge backseat is pretty standard, in a range of about 1/8 to 1/4". And the backset or inset is controlled by hinge or mounting plate, or both.
The wide overlay is usually a straight body part, and thin mounting plate. Insets need cranked necks and or higher mounting plates.
Re: It would help if you gave mor hinge info.
Ed in NY
Sorry Keith, yes, they are european concealed hinges. That's what i kind of figured. Just to be sure I guess I'll do some tests on scrap wood to see if I get a true 5'8" overlay with where the hole is cut.
http://www.homedepot.com/h_d1/N-5yc1v/R-100147531/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=5%2F8%22+hinges&storeId=10051
I don't have much experience with the Euro style hinges, but one thing to be careful about is the profile and width of the Stiles on the doors. If the stiles are too thin you can drill through them. If they are too narrow you can drill partially out the inside. The profile can mess you up also. If the edge has a ogee or other shape in it, the pocket hole can "surface" through the molding and you can drill into the groove and/or the panel. Consider that before you make the doors.
Ed in NY
Thanks Barry, I'm following all of the standad procedures...using 3/4" stock, rails and stiles are 2 1/4" wide, etc. I will have to use some kind of depth stop to prevent drilling though the face though!
Dick Coers
Keith is right, but you will see it in charts as 3,4,5, or 6mm from the edge. 1/8"=3.18mm and 1/4"=6.35mm I've either used a drilling machine, or drill press with a fence to drill the doors. Does that jig require you to use a hand drill? Also on some router bit door bits, a thick panel will stand proud of the rails and styles. Pay attention to what bit set you get, or a drill press table will need some shims to have it flat to drill.
Moses Yoder
Moses Yoder
The instructions with the hinge should say how far from the edge of the door to drill.
