200+ woodworking book reviews
connecting shelf unit to desk top
Jerry Gibbs
Planning to build an oak desk for my grandson. The desk top is 36" x 60". I want to add a shelf unit to stand on top, but be removable for transport. The shelf unit will be approximately 12" wide with height to be determined. I don't want the shelf unit to tip over. I don't know what type fastener or system to look for. It seems like a common design issue. Jerry
Re: connecting shelf unit to desk top
Crazy suggestions
Merle
Jerry, just a couple thoughts that may be totally off the wall. Would your design be able to accomodate sliding dovetails that would open to the back? Another option would be to drill holes for pegs that could be left unglued for easy removal. HTH
Gary Smyth
Gravity is your friend. Build it square and level and set it on the desk. I suggest that you install a couple of removable dowel pins in the desk and the mating holes in the bottom of the case. That will hold the bottom from sliding and still be removable. At or near the top you can install a earthquake cable and that will stop a toppling over with a odd hit.
My son got a hutch - four feet long, six or more feet tall - for his girlfriend (since they now live together, I guess he was getting it for himself, too; he just didn't know it at the time). The shelf unit on top was held to the base unit with four to six screws, coming up from below into the bottom of the shelf unit. The shelf unit, constructed with those screws in mind, so the screws ran into side grain, not end grain. It was quite sturdy.
Pete in Holland MI
Design the shelf unit to be flush with the back of the desk. Put a steel strap (bout 3" long) between the desk and bookshelf vertical members. This will keep it alligned left to right and front to back, and keep it from falling forward. No issue with it falling backwards on a desk up against the wall. 4 screws, and the thing is off for transport !
Pete
Jerry Gibbs
That sure is practical if not elegant. Jerry from Grand Haven, MI
AZ in Colorado Springs
That's how my computer desk is built Definitely nothing elegant about it, but it's useful and not unattractive.
Pete in Holland MI
It is strong (screws are in shear), and doesn't affect the top of the desk like dowels or other fasteners would. This is a benefit if the user decides he doesn't want the book shelf on top anymore. It is also easily removable during a move.
So long as it is up against the wall, it is a practical solution, with the above benefits.
Pete
