Getting old, and have a larger yard at my new house. So, I need a yard leaf vac/shredder. I plan to use this only on leaves, not grass clippings. I don't need a chipper since I have a nice fire pit for limbs, etc. With my bad knees and a few small inclines, I need either a self-propelled unit or one I can pull behind my Cub Cadet. I'm looking for a good (not junk, not cadillac price either) yard vac/shredder that will reduce volume and pick up most yard waste, and that will last for more than a couple of seasons.
Can anyone offer advice or personal experience on what to look for (brand, features, etc.) or, just as important, what to avoid?
My AgriFab tow-behind vac is about fifteen years old, and it's been pretty much troublefree. It hooks, via flex hose, to the discharge port on my JD tractor.
They're a bit pricey, but so are nearly all the other yard vacs, so I guess it's just the 'price you pay to play' sorta thing.
you could use a two or three bag rear bagger. First install the Cadet mulching blades for the deck and coupled with the bagger, together, they do a surprisingly good job. (It is a pain in the tail to initially assemble bagger and the same to later store the collection tube and frame, but no more than alternatives.) For early fall I mulch only and it does well, as the leaves almost disappear. When the leaves get big time I cut the grass and mulch first and then go over with the bagger. With the now smaller leaves the bagger stores more and although the bags fill rapidly the piles of mulched leaves will bring you a smile in the spring when you need mulch. If there is a lot of ground I dump the bags around the trunk of the tree or in the garden plot for over wintering. If you build a pile the collected mulch can also be used to heel in Christmas trees, if live. You will need to cut, mulch, and collect when the lawn is NOT wet. The bagger runs about $360 (Amazon) for a two bag unit.. Look around, check it out it might work for you and be a less expensive alternative.
Plus 1 on the Agri-fab. Mine is about 7 years old, and it gets a workout, from the 30+ mature maple trees around my lawn. I also use it regularly when trimming all of the bushes and so on. I throw the waste out on to the lawn and mow it up with the Agrifab attached. Does a good job of shredding. I'm always amazed how big a pile of leaves I can mow up before having to empty it. Mine has been problem free, except that the 6" hose gets torn off and beat up once in a while. The 6" hose clamps aren't quite strong enough to hold the hose when you are brushing up against bushes and so on. I doubled up on the hose clamps, and that helps. There is a kit with a 15 foot 5" hose with a handle that works really well for vacuuming out the flower beds in the spring, or vacuuming up piles of leaves. Mine has the chipper, but I almost never use it. It doesn't work very well. They are kind of a pain in the neck to empty. I have figured out that the best way is not to try to tilt dump it, but just open the back and pull out the leaves with a rake or hoe, or a mulch fork.
I have the same problem with the hose occasionally coming loose. I guess if it didn't come loose when snagged, it could cause some damage to tither the vac unit or the mower deck, so it's sort of a 'live-with-it' problem.
As for emptying the trailer, I too have found dumping it more trouble than it's worth, so like you, I use a pitchfork and/or rake.
BTW, used mine just yesterday to pick up an acre+ of oak and maple leaves. Starting early this year - on account of the Summer drought, I guess...
I had that setup for my last John Deere tractor. It worked fine for grass clippings, but with about 25 large oaks and maples on my property, it'd fill both bags with leaves about every fifty feet of mowing. The trailer mounted unit works much better.
