tool info needed
tool info needed
tool info needed
grandy
https://picasaweb.google.com/115252728742818509638/20120912?authuser=0&authkey=Gv1sRgCIWFrP-osPnzQw&feat=directlink
does anyone know what this is for and what it's called. I purchased a shot and this
was with the forged hold-down so I though it may have something to do with the
workbench.
Thanks, Sandra
Re: tool info needed
Ralph Lipeles
It's for holding work to the workbench top. It is used with a bench that has a solid top and through holes for dogs. Position the work, insert the long section into one of the holes and tap it into place. When finished, tap it up from below and it will release and can easily be removed.
Ralph Lipeles
grandy
the holder-downer-thingie I found at Woodcraft, but what
is the other thingie used for? Anybody know or is it something
not even suppose to be in the tool box.
Henry Higginbotham
Hmmm . . . somehow I didn't see the sheet metal piece the first time around and misunderstood what you were asking. I still don't know what it is, but I'll be interested in knowing if it has something to do with woodworking.
It looks to me like a
Gary Smyth
portion of a power table saw hold down. Connected to the plate is a clear saw blade cover and the saw tooth anti-kickback fingers. That may be the support for a splitter. My impression is that it has nothing to do with the bench dog hold down. The thin plate I have that looks similar to what you show. Mine is an older JTS-10 Jet. The illustration shown here is also a Jet but not as close what you linked. The plate fitted to the saw blade insert opening.
Another possibility is it served as a bracket that attaches to the rear of the saw and protects people's fingers from the drive belt pulley
Re: It looks to me like a
grandy
Thanks Gary, Being a turner and small flatwork woodworker
I couldn't figure it out. I do know it's cast iron and very heavy.
Would like to find someone with a need for it, however, it would
be costly to ship due to weight.
Sandra
