OT How to clean really dirty vinyl floor?
One of my rental houses has some really dirty vinyl flooring. Looks like they just walked the dirt into the floor for years. Is there some sort of cleaning solution that might soften the dirt? What type of scrubber would you use? Waht woudl you put on the floor after its clean?
Re: OT How to clean really dirty vinyl floor?
Joseph Mulherin, sr
Barry, I did an Internet search and this is the answer I found: Wash the floor with ammonia and water and use a Spick & Span red scrubbing pad; let the ammonia sit for a while then wipe up and let dry. Then cover the floor again with a clear acrylic solution to get the shine back.
Simple green or TSP
JMOHNIKE
Have had to do this may times. Use a good floor stripper for removing wax. pour it on full strength. I have had it remove gum, grease, paint splatter etc. Don't forget to spot test it first. I have had no problems useing it on the socalled no wax floors, and does not affect the finish.
Galen Vetterick
If this has been going on for years, as you noted, I'd only test clean a small area and see if the wear surface is gone from the vinyl. May be easier to put down a new floor and get some better renters.
Bill Roland
Try some "Awsome" from Dollar General store. I have also found it in Wally World. It works just like the name. You can delute it first or try it full strength.
