This is a gable vent on the end of the shed my son and I have been working on. The birdhouse is made out of scrap Azek and scrap wood. The holes in the birdhouse are 2 inch soffit style push in vents that exclude bugs and still let the air flow through. The vents are painted black and the area behind the birdhouse has been cut out to let the air flow freely. The scraps have been glued and screwed together but still provide an interesting view from the road.
You're saying it's not really a bird house? It's a vent that looks like a bird house. You're lucky pigeons don't have lawyers, or you might get sued for fraud. If I were a pigeon, I think I'd be fooled.
I looked at the html source code of the WoodCentral page you posted with the little blue question mark, found the URL of your photobucket album that you pasted into your post, stripped off the extraneous junk that Photobucket supplied, found the album on photobucket, figured out which picture you probably wanted to display, opened the picture in a new window, copied its URL (which ended in .jpg) and pasted it into the Optional Image URL box of my reply message.
If you are unsure in the future if you have the correct address of a photo, hit the "preview" button at the bottom of the Reply dialog page (instead of the Post button), and see if the picture comes up. When you like everything about your post, the text, photos, formatting, smiley faces (emoticons) and links, then hit the Post button.
Nope, that's a web page coded in html, not a jpeg image. Everything starting with the first question mark is parameters passed to the photobucket webpage to tell it what to display.
The address of the image itself (in photobucket's database, on their server) is
I'm not sure I understand the question. But, more important, I don't try to understand any web-based photo hosting site's psyche (or business model, if that's what they want to call it). In general I try to avoid using them, both for archival and copyright ownership reasons. Photobucket's obfuscation methods are pretty transparent, and easy enough to get around, but other "services" are much less so. For example, I would discourage anyone from ever using Shutterfly. There's no way I have yet found to move an image from their database, even one you have created yourself and stored there yourself, to some other place on the web where you can share it with others. I would classify them as "predatory."
I don't mind at all putting images I have created (and other wisdom) on WoodCentral (and I encourage others to do so), because your ideals are in line with mine. I would strongly recommend that anyone who owns an image related to woodworking community, whenever possible, to use the "choose file" button on this page, instead of the "optional image url" box.
