Dust Panel Hole Layout, Size and Quantity
George Colonel's Workshop
Good Afternoon Friends,
I'm at the stage of making things again. To ease into "work", I decided to re-task my table saw right wing ito a sanding surface, repleate with under-table DC/Vacuum. It measures 27" X 15 1/4". My present right wing extension is a simple torsion box, which is glued shut. I have a used table top of particle board/plastic laminate which I can mount as a right table wing. I'll need to drill dust evacuation holes in it, and create a bottom to attach the suction device. I'll also need to keep the structure hollow for internal air/dust flow flow. Please comment.
George
Re: Dust Panel Hole Layout, Size and Quantity
1. That project sounds like it'll really suck.
2. No dust on you, Colonel!
3. Why don't you just wing it?
4. I'm sure, when you're done, the hole thing will be quite impressive.
Not too be as punny as Bill - but it depends on what size hole "liners" you happen to have.
The best set-up I've seen for a table had small plastic grommets or flanges that fit into the holes. They provided protection for the hole edge. They were also inset a bit into the surface so you could easily slide a board over them.
If you can find a source, that's the size I would drill the holes.
Joseph Mulherin, sr
Hello, George, as JL mentioned, try going to say HD or Lowes and look at the brass gromment
holes protectors....and sink them just a little so they are flush with your table top. I would make the table top look a little like a pegboard...but not as many holes...just enough to get the dust cleared.
