use mineral spirits to find glue squeezout?
phileas
Hi all,
I built some bookcases out of birch plywood, and made what I'm sure is a common mistake. I used too much glue on some of the joints and ended up with a row of pinhead-size beads several inches in length along several of the joints. I wiped up the excess glue when it was liquid using several paper towels to avoid as much as possible spreading the excess (it's not as bad as it sounds, I hope ). However, I'm sure some of the excess glue remained in place and has now dried.
I seem to recall someone suggesting applying a small amount of mineral spirits to identify where the excess glue had penetrated the plywood, but a quick search of the message boards yielded no results. In any event, my plan is to use the mineral spirits to find the excess glue, and then sand ever-so-carefully to minimize the irregularity to my finish.
Recognizing I'm not going to achieve perfection (and really, who amongst us does?), do I have a sound plan for minimizing the visual consequences of my mistake? What improvement(s) would you offer?
Thanks,
phileas
