Laptop to small TV?
Laptop to small TV?
Laptop to small TV?
tom
I was wondering what would be a low cost solution to the following. I would like to use my laptop to watch cycling training videos. But I would like a larger screen. I would set this up in front of my trainer. Not really sure what to look for.
Thanks
Re: Laptop to small TV?
Kurt
If you're lucky, it's pretty easy. Does your TV have a VGA or HDMI port? Or does your laptop have an HDMI port? If so, you just need the appropriate cable. If you need a VGA or HDMI cable, I'd think about not getting one from a big box store; they tend to be rip-offs. I've had pretty good luck with monoprice.com. There's usually a key combination on the laptop that will switch between the built-in screen and an external monitor, something like + or similar. Modern TVs are essentially computer monitors with a TV tuner and audio built in.
Alan in Little Washington (NC)
+1 on Monoprice and an HDMI cable- do that all the time with my laptop and 46" LCD Samsung.
John McGaw (Bodger)
I've had good luck with Amazon's "basic" cables which are of good quality and reasonable price. Plus, if you go there through the link on WC the site will earn a little kickback (very little on a cable but you have to start somewhere). As was written earlier, there are a number of permutations of connections on the computer and monitor. Some are dead easy such as HDMI to HDMI or Displayport to HDMI. On modern equipment these are the common options. On antique equipment you might find anything down to a 15-pin VGA connector and on old TVs you might find RCA connectors for composite video or S-Video -- there you might start to run into a few more problems and expense.
William Duffield
If you have a Mac, you just plug it in. No arcane software settings to fool with. No hassle with choosing which screen you want to use, either. Both screens work at the same time, independently. You can watch your TV program on one screen and read WoodCentral on the other one. But you might need a HDMI to mini-HDMI adaptor cable, depending on the model of your Mac.
Jason Waters
Just make sure the TV has the right input for your laptop output and you are good. Monoprice or Amazon is fine for the cable, I've used both. Don't get ripped off at the big box store.
I have a 22" Ario LED TV in the kitchen. It was like $119 after rebate from CompUSA. Not sure what inputs it has, but the picture is suprisingly nice for the price.
Jesse Cloud
Even better, if you have a Mac, get the Apple TV box. Among a lot of other things it does, it will connect wirelessly to your Mac and display whatever is on your screen on the TV. We use it a lot to view camera snapshots on the TV.
William Duffield
But, I don't have a TV >(
Skip the "Shack"
If your Radio Shack is like ours I would say to skip going there for cables. They push you to buy expensive ones, try to sell you an extended warranty for the cables (really?) and then of course you spend 20 minutes at the register while they interrogate you for info to use for their spam.
Re: Skip the "Shack" yeah but
Bob Entwisle in NJ
I'll be sad when the shack goes away.
Where else can you go on a Saturday afternoon to pick up a diode or transistor?
Bob in NJ
Hi-jack question, sort of....
Walking through Lowe's I noticed HDMI cables for $10 for a six foot cable. I take it Lowe's is not the "big box" mentioned above????? This seems dirt cheap to me. Of course, the cable probably has carbonized sawdust for wires and wooden plugs, being in Lowe's and all.
Re: Hi-jack question, sort of....
Bill Howatt
I took "big-box" in this post to be something along the lines of Best-buy. I think "big-box" isn't really the issue since you can pay way too much for cables at small specialty stores too.
I bought a micro-HDMI to HDMI 6' cable from Amazon, actually one of the suppliers linked through Amazon, for $5 and that included shipping. It works fine and appears to be as well constructed as any cable.
Bill
Agree...
John in NM
"Bad cable" is, I think, just a very convenient scapegoat for not understanding fairly complex problems. But the company's tech support never uses scapegoats :D :D :D
Sometimes however, too many adapters on a cable will cause problems - the little VGA to HDMI adapters for example give you a signal considerably worse than a VGA connection.
Re: Agree...
tom
I checked the back of a TV that I have and it only has the white, red, and yellow jacks no HDMI. So does this mean that this TV will not work with a computer?
Thanks
