Work bench height?
Work bench height?
Work bench height?
Bill Roland
I am building a workbench at the Tennessee Disaster Relief Mission Mobilization Center and need you opinions on work bench height. I am a little height deprived compared to the average guy today and like 36", however for working off a stool I think 39" works better. What are your suggestions?
Re: Work bench height?
Joseph Mulherin, sr
Bill, consider this work bench: www.jack-bench.com.
I bought the plans and built it last year and it does suit my needs to a tee.
You can move it around on wheels, and raise the work table up for about 15", then lock it all and do the work you have going on ....in comfort .
AZ in Colorado Springs
Depends on the projects you're building.
I'm not exceptionally tall -- 6'1" -- and my work bench (w/ casters) is 36" tall. Doubles as an outfeed table for my table saw (also on a mobile base).
I'm currently building a blanket chest (25" tall), and now that the case work is assembled, I'd like to have a shorter bench for a while.
My router table, alternately, is about 40" tall. It's a Rockler laminated top with a base that I built. I don't want to have to bend over and get a back ache routing things. (The Freud table is much shorter, probably around 30" tall).
I've read that hand tool users prefer a bench on the shorter side so they can put their body into the tool motion, and the work processes differ a bit.
So I think the answer to your question begins with how the bench will be used.
Jesse Cloud
As stated above, it all depends on what kind of work you will be doing. Pick out a couple of activities and try them on a flat surface at a few likely heights (build up the height with lumber or cinder blocks for the test).
What's important is YOUR COMFORT, so don't spend a lot of time looking at what other people do.
And, if you mess up, its a lot easier to make a bench taller than to make it shorter!
One more thing, if you do a lot of close work such as dovetail sawing or inlays, consider a small bench that can clamp on your regular bench to bring things up to your chest level or so. Google "Steve Latta inlay bench".
Good luck, and let us know how it comes out!
Bob
Bob
I find that for me 34" is good. I am 5' 9". The way I came to that it I measured from the floor to my knuckles when I make a fist. I am in the process of making a new bench now. What I did first was to build a mock up from 2bys and a sheet of 3/4" ply and went through some of the motions I would do while planning, cutting dove tails, using a mallet and chisel adjusted the height by standing small sheet scraps of ½” and ¾” plywood to see if any other height was better and 34” was my magic number.
steve mackay
One of the best decisions I ever made . . . I stood up and measured where it was comfortable to work, then I sat on my "bar" stool and measured where it was comfortable with my elbows on the bench. Then I split the difference. Now I can stand there and plane all day or sit and fiddle with small stuff.
Dave Bair, Eaton Rapids, MI
Mine's 1/2" lower than my table saw so it can act as an extended outfeed. For work with hand tools, lower is better. For power tools, higher is better. Mine's a compromise, but a useful one.
James Sholtis
All of the answers to the question had very logical responses and reasons for thier choices. The one answer I did not see among them was an answer that solves the whole problem. Most workbenches have wooden legs. With wooden legs special tools are not needed to make any height adjustments to them. what would be wrong with having the best of both worlds for your workbench? Find out what heights work best for you, both the lowest height and the highest. Most of the time the difference between the two is less than 10 to 12 inches. What would resolve this height when going from a shorter height to the taller height would be pieces of 3/4 plywood longer than the width of the workbench and taller than the difference in the height of the two. By making the table legs sandwiched between the two pieces of plywood, you can stablize the bench a little more, adjusting for an uneven floor and raising or lowering the height all in one felled swoop. This wouldn't be practical for a project that needed to jump from one height to the other quickly, but would serve both problems if change wasn't needed to be done right away.
